    M5StackCore2 Can Port A be used as Serial port ?
    2 Posts 2 Posters 2.3k Views 1 Watching
      talktosanjay3
      Hi All,
      I am new to m5stack. I just wanted to understand if PORT A on the device can be used as a software serial? If so what is the PORT numbers i need to use? I tried G32 and G33 with no luck.
      • felmueF Online
        Hello @talktosanjay3
        by default port A is for external I2C; however M5Core2 uses two dedicated GPIOs (32/33) for port A so it should be possible to use it for anything as by default external I2C is not being initialized.
        Can you share the code you tried?
