    [SOLVED] Can't reset my M5StickC Plus
    9.1k
    • Matej's WorkshopM
      Matej's Workshop
      Hello, I got my M5StickC Plus and when I upload an arduino code then the power button doesn't reset the device when pressed.
      Sometimes it's annoying when I want to quickly restart the device, so then I need to turn it off and turn it back on.
        Hello @MatejTech
        afaik the M5StickCPlus power button can only be used to turn the device on and off. The power button doesn't have reset functionality and there is no dedicated reset button. So yes, the only option is to turn it off and on again.
        • Matej's WorkshopM
          Matej's Workshop
          @felmue Hello, but when I burned UiFlow onto the M5StickC Plus it is possible to reset it 🤔
            Hello @MatejTech
            correct, but in this case the reset functionality has been added programmatically by UIFlow.
            M5Stack did the same in the M5StickCPlus factory code. See here.
