    m5go World Clock Problem
    Scheduled Pinned Locked Moved M5GO
    3 Posts 3 Posters 4.8k Views
    • L Offline
      lorin
      Hello
      I am trying to create a world clock on the m5go. But if I want to display several times at once, an error comes up after a few seconds because the m5go is overloaded. Is there a solution to this probelm?
      LG
        holofloh
        your question reads like "my car will not start, what shall I do?". The standard answer to that question is "buy a new car" even if the solution would be as easy as "turn the key" or "fill some gasoline".
        From your description we know you want to have a world clock and you have a m5go. What is missing:
        • The environment you use to code your clock
        • Your code which seems to be the problem
        • the exact error message or a picture of what you call "overloaded"
        please read this post first: https://forum.m5stack.com/topic/535/forum-rules-read-this-first-before-posting
          What exactly is the issue?
          What hardware are you using?
          What error messages are you getting?
          What code are you using?
          What have you tried to fix the issue?
