    RTC UI Flow - GET RTC doesn't work
    3 Posts 2 Posters 3.5k Views 1 Watching
      mickud
      I am struggling with RTC module M5Unit-RTC: https://docs.m5stack.com/en/unit/rtc
      I know it's working, and powered on, because it responds correctly to alarm, and timer commands.
      However when I try to use the GET RTC (seconds) command it fails.
      I tried everything: changing it to int(), assigning a variable with the get_rtc() - nothing helps
      I am attaching an example.
      The behavior is as follows:
      • LED turns to yellow (inicialized)
        after 3 sec LED turns to Blue (the date and time is set)
        Instead of going to green the LED goes to <red> the moment a line with get_rtc command is being run.
        It's always the same with every other things I try. The moment I use this block the LED turns red and stops working.
      I am looking forward to hearing your thoughts
      Michal
      • felmueF Online
        Hello @mickud
        • which device (M5AtomLite, M5AtomMatrix, M5Stamp, ...) are you using?
        • what UIFlow firmware is running on your device?
        I've tried with an M5AtomLite and M5StampPico (both UIFlow firmware version 1.11.0) and using get_rtc command works just fine for me.
        BTW: convert to int seem to be unnecessary.
          mickud
          I am using Atom Lite. It's the one from ATOM Stepper Motor Driver Development Kit (DRV8825)
          I am using UIFLOW(LITE) v1.9.8 downloaded using the Burning Tool
          I checked if the Burnning Tool would update the UIFLOW version, but I did not download the newest Burning Tool version. That must have been a mistake.
          Now I downloaded the newest Burning Tool with UIFLOW 1.11.0 on board and it is working correctly.
          Thank you Felix. Much appreciated!
