    Issue with Env-iii hat.
    4 Posts 2 Posters 5.4k Views
    • G Offline
      goochiecobbler
      Having an issue running the following code with the env-iii hat. Any help would be appreciated.
      #include <M5StickCPlus.h>
      #include "M5_ENV.h"
      SHT3X sht30;
      QMP6988 qmp6988;
      float tmp = 0.0;
      float hum = 0.0;
      float pressure = 0.0;
      int status;
        //M5.Axp.ScreenBreath(8);
        M5.Lcd.setRotation(3);
        Wire.begin(0,26);
        qmp6988.init();
        pressure = qmp6988.calcPressure();
        status = sht30.get();
        tmp = sht30.cTemp;
        hum = sht30.humidity;
        M5.Lcd.fillScreen(BLACK);
        M5.Lcd.setCursor(0, 0);
        M5.Lcd.printf("Temp: %2.1f\r\nHumi: %2.0f%%\r\nPressure:%2.0fPa\r\nStatus: %d", tmp, hum, pressure, status);
        delay(4000);
      04:49:47.756 -> [ 2][I][esp32-hal-i2c.c:75] i2cIni��): Initialising I2C Master: sda=32 scl=33 freq=100000
      04:49:47.756 -> [ 5][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
      04:49:47.796 -> M5StickCPlus initializing...[ 78][I][esp32-hal-i2c.c:75] i2cInit(): Initialising I2C Master: sda=21 scl=22 freq=100000
      04:49:48.391 -> OK
      04:49:48.391 -> E (645) ledc: freq_hz=0 duty_resolution=13
      04:49:48.391 -> [ 649][E][esp32-hal-ledc.c:75] ledcSetup(): ledc setup failed!
      04:49:48.391 -> [ 649][W][Wire.cpp:301] begin(): Bus already started in Master Mode.
      04:49:48.391 -> [ 653][W][Wire.cpp:301] begin(): Bus already started in Master Mode.
      04:49:49.506 -> [ 1760][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263
      04:49:50.512 -> [ 2761][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263
        Hello @goochiecobbler
        not sure, what is going wrong. But the Arduino Wire library has changed in the past and has broken some previously working examples.
        There is a hint in the log about 'Bus already started in Master Mode' so you could try adding a Wire.end(); before the Wire.begin(0, 26); and see if that helps.
        • G Offline
          goochiecobbler
          That did fix it, thank you so much. <3
          I did notice that error, just still familiarizing myself with arduino and wasn't sure how to go about it.
          Working code follows for anyone wondering.
          #include "M5_ENV.h"
          SHT3X sht30;
          QMP6988 qmp6988;
          float tmp = 0.0;
          float hum = 0.0;
            Wire.end();
            Wire.begin(0,26);
            qmp6988.init();
            sht30.get();
            tmp = sht30.cTemp;
            M5.Lcd.printf("Temp: %2.1f\r\nHumi: %2.0f%%\r\nPressure:%2.0fPa\r\n", tmp, hum, pressure);
            delay(1000);
            I am happy to hear it worked. And thank you for reporting back and posting the working code.
