    Ultrasonic I2C problems
    2 Posts 1 Posters 3.9k Views
    • I Offline
      ispybadguys
      I have a problem with the I2C version of the Ultrasonic distance measuring unit. If I connect it together with the MLX90640 Thermal Camera Unit the Camera data is corrupted. If I load and run the Demo and only connect the Ultrasonic distance measuring unit every other sample has the distance 4500mm. If I use this code it works fine in the demo but still corrupts the Thermal camera
      uint32_t data;
      Wire.beginTransmission(0x57); // Transfer data to 0x57.
      Wire.write(0x01);
      Wire.endTransmission(); // Stop data transmission with the Ultrasonic Unit.
      delay(120);
      Wire.requestFrom(0x57,3); // Request 3 bytes from Ultrasonic Unit.
      data = Wire.read();data <<= 8;
      data |= Wire.read();data <<= 8;
      • I Offline
        ispybadguys
        It seems if I set the i2c rate to 100Khz this works.
