    PortA i2c unit not recognized in Core2 when stacked onto Servo2?
    6 Posts 2 Posters 6.4k Views
      swiminthesky
      I am using ExtIO2 unit with Servo2 stacked beneath Core2, but the Extio2 module is not recognized ("extio Connect Error").
      I am using the newest Extio2 library on with extio.begin(&Wire, 32, 33, 0x45) and beginning M5.begin(true,false,true,false,kMBusModeInput). This pins shouldn't be a conflict, as Servo2 is running by default on the internal bus wire1.begin(21,22).
      The Extio2 is recognized instantly at portA when used without the Servo2.
      Anyone has an idea what could cause this?
      • felmueF Online
        Hello @swiminthesky
        I assume you are using an external power supply for the Servo2 module as suggested here. I also assume that the Servo2 module on its own works fine, correct?
        Are there any errors in the debug output? Maybe I2C related.
          swiminthesky
          Thanks Felix @felmue,
          external power is used. Servo2 example (on Wire1.begin(21, 22);) also works like a charm.
          I used both these M5 i2c scanners I2CScanInternalAndAllPorts and I2C_Tester, but no I2C devices are found.
          But after removing Servo2 the device is instantly found correctly!
          (Also: I used PaHub on PortA inbetween and Extio2 is also instantly found when Servo2 is not stacked)
          (ext power is not used for the picture, the Bottom2 also didn't make a difference afaik)
          • felmueF Online
            Hello @swiminthesky
            hmm, not sure what is going on.
            Maybe the Servo2 library still uses Wire somewhere internally?
            Could it be a mechanical problem?
            BTW: my I2CScanInternalAndAllPorts is for M5Paper - I have not tested it on other M5Stack devices.
              swiminthesky
              Yes, it seems to be a hardware problem! I switched the Servo2 module and everything works perfectly and the i2c connections over port A runs without any interruptions. Thanks Felix @felmue and sorry for bothering!
              • felmueF Online
                Hello @swiminthesky
                no worries. Thank you for reporting back. I am glad it now works for you.
