    Pure Micro Python without Ui-Flow on my M5Stack core2
    23 Posts 8 Posters 75.1k Views 5 Watching
      purpledread @dhed
      @dhed
      I tried to get your compiled firmware, but that ZippyShare site keeps trying to download other things and I can't get it to download your file.
      Thanks,
      /Chris
        dhed @purpledread
        @purpledread That link still works for me, but here it is uploaded to an alternative.
          purpledread
          Thanks, the new upload link worked.
          /Chris
            purpledread
            @dhed
            That's all working now, including using ampy to copy files and run code.
            I'm use to using Mu Editor with my other ESP32 boards.
            Is there some way to run Python code and get back error messages if there is an issue in the code?
            Thanks!
            /Chris
              dhed @purpledread
              @purpledread
              I'm using VSCode with the PyMakr extension (see LeMaRiva's blog for install-instructions).
              Nice IDE with integrated serial-console for REPL and up-/downloading of files.
              But I guess any serial-console (i.E. PuTTY) should allow you to see error messages.
              Also check micropython.org for instructions to get a REPL over the serial port.
                purpledread @dhed
                @dhed
                Actually, ampy is working fairly well.
                Thanks,
                /Chris
                  purpledread @dhed
                  @dhed
                  I'm trying to read from the SD card on startup and then use the display.
                  If I access the sd card, the program runs with no errors, but nothing displays.
                  I tried initializing the display using the example you gave, but I get an error that there isn't enough DMA-able memory to allocate the display buffer.
                  /Chris
                    purpledread @purpledread
                    @dhed
                    Sorry for the newbe questions. You've been a big help.
                    When you say you load files to ram from the boot.py file, how do you access that ram from the main.py file?
                      @purpledread
                      Never mind. As simple Python code.
                      Thanks!
                        Snufkin1514
                        Is it possible to use m5stack_ui here?
                        How do it?
