    RFID2 Unit and Core2 Processor
    Units
    4.6k
    • F
      falbriard
      I've bought an RFID2 reader/writer unit which I connected to the M5 CORE2 processor.
      Using the web based UIFlow, I do not see a specific unit type RFID2 to add to the unit list. For this reason I've added the default RFID and the basic functions are OK and support functions like "card near", tag ID, read and write from address x, like 1. With few UIflow commands and a logic loop I was able to build a basic RFID Tag reader & writer and also to get the UID information.
      Please clarify in some more depth the use of read from "addr" and write to “addr”.
      My guess is that "addr" means sector number, where we find 16 sectors each constructed with 4 blocks, as shown in the memory reader of the "Android NFC Tools – function Memory Hex". There are 3 blocks of data, each 16 characters long, followed by one block of keys.
      Sector 0 is used for UID.
      Sector 0 → UID
      Sector 1 → Data1
      Sector 2 → Data2
      Sector 3 → Key
      Sector 4 → Data3, etc
      My doubt: By writing into "addr" 3, does it overwrite the key in sector 3, or does it write into sector 4 data field, by this preserving the key address? Overwriting a key field possibly would destroy the default RFID tag format. Hope there is code example available for this topic. Below see a hardcopy of my code: 0_1665152588676_rfid_code_sample1.png
      • F
        falbriard @falbriard
        @falbriard 0_1665413893147_rfid-mirafecard_layout.png Might be useful to illustrate the topic, attached you find the RC522 Mifare tag memory layout.
        • F
          falbriard
          Using the UIflow code, I wrote data into the RFID addr 1, 2 and 4. Checking the result with Android "NFC Tools", function "Read Hex Memory" I see all the data written into the corresponding sectors in a hex format.
          "addr 1" is "sector 0, Block 1"
          "addr 2" is "sector 0, Block 2"
          "addr 4" is "sector 1, Block 0"
          My guess is that the following write sequence will preserve the formatted key addresses
          and make good use of the available Mifare tag memory space, organized in 16 bytes blocks.
          The resulting addressing table for writing data is:
          Data addr: 1,2,4,5,6,8,9,10,12,13,14,16,17,18,20,21,22 .. etc
          reserved
          UID addr: 0
          Key addr: 3,7,11,15,19,23 .. etc
          • F
            @falbriard An attempt to write a logic with Blockly & MicroPython code (via UIFlow), able to store up to 1000 characters on a RFID tag:
            # by Claude Falbriard - QcLab Brazil
            # RFID tag with RC522 layout
            from m5stack import *
            from m5stack_ui import *
            from uiflow import *
            import time
            import unit
            screen = M5Screen()
            screen.clean_screen()
            screen.set_screen_bg_color(0x000000)
            rfid_0 = unit.get(unit.RFID, unit.PORTA)
            inputsrt2 = None
            elecounter = None
            alldata = None
            inputstr1 = None
            inputdata = None
            inputstr4 = None
            cardready = None
            label0 = M5Label('RFID Reader', x=10, y=10, color=0xf5f2f2, font=FONT_MONT_14,
            parent=None)
            text_2 = M5Label('text_2', x=10, y=113, color=0xb1ed94, font=FONT_MONT_14,
            parent=None)
            text_4 = M5Label('text_4', x=10, y=138, color=0xccf1a6, font=FONT_MONT_14,
            parent=None)
            debug1 = M5Label('Debug: ', x=10, y=226, color=0xf09a9a, font=FONT_MONT_14,
            parent=None)
            alldata_label = M5Label('alldata', x=10, y=170, color=0xdff2d7, font=FONT_MONT_14,
            parent=None)
            inputd1 = M5Label('input data', x=10, y=48, color=0xe8f081, font=FONT_MONT_14,
            parent=None)
            text_1 = M5Label('text_1', x=10, y=88, color=0xcbeeb9, font=FONT_MONT_14,
            parent=None)
            elecounter = 0
            # constructing an RFID RC522 compliant data writer
            # https://www.blindtextgenerator.com/lorem-ipsum
            # generate a string with max length of 1000 characters
            ipsumstr = """Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Aenean commodo
            ligula eget dolor. Aenean massa. Cum sociis natoque penatibus et magnis dis parturient
            montes, nascetur ridiculus mus. Donec quam felis, ultricies nec, pellentesque eu, pretium
            quis, sem. Nulla consequat massa quis enim. Donec pede justo, fringilla vel, aliquet nec,
            vulputate eget, arcu. In enim justo, rhoncus ut, imperdiet a, venenatis vitae, justo. Nullam
            dictum felis eu pede mollis pretium. Integer tincidunt. Cras dapibus. Vivamus elementum
            semper nisi. Aenean vulputate eleifend tellus. Aenean leo ligula, porttitor eu, consequat
            vitae, eleifend ac, enim. Aliquam lorem ante, dapibus in, viverra quis, feugiat a, tellus.
            Phasellus viverra nulla ut metus varius laoreet. Quisque rutrum. Aenean imperdiet. Etiam
            ultricies nisi vel augue. Curabitur ullamcorper ultricies nisi. Nam eget dui. Etiam rhoncus.
            Maecenas tempus, tellus eget condimentum rhoncus, sem quam semper libero, sit amet
            adipiscing sem neque sed ipsum. N"""
            # chop test data string to 256 bytes
            ipsumstr = ipsumstr[:256]
            # split a text into 16 bytes elements, max size = 1000
            def split_by_n(seq, n):
                '''A generator to divide a sequence into chunks of n units.'''
                while seq:
                    yield seq[:n]
                    seq = seq[n:]
            rc522list = list(split_by_n(ipsumstr, 16))
            blkcount = len(rc522list)
            # process list by RC522 element max 1000 char
            validptr = [1,2,4,5,6,8,9,10,12,13,14,16,17,18,20,21,22,24,25,26,28,29,30,\
                        32,33,34,36,37,38,40,41,42,44,45,46,48,49,50,52,53,54,56,57,58,\
                        60,61,62,64,65,66,68,69,70,72,73,74,76,77,78,80,81,82,84,85,86]
            keyptr =  [3,7,11,15,19,23,27,31,35,39,43,47,51,55,59,63,67,71,75,79,83]
            while True:
              alldata = ''
              inputstr1 = ''
              inputsrt2 = ''
              inputdata = ''
              inputstr4 = ''
              cardready = False
              wait(1)
              debug1.set_text('start reading ...')
              if rfid_0.isCardOn():
                debug1.set_text('card found')
                inputdata = rfid_0.readUid()
                speaker.playTone(740, 1/2)
              inputd1.set_text(str(inputdata))
              elecounter = 0
              for ele in rc522list:
                 blkdata = ele
                 blkaddr = validptr[elecounter]
                 rfid_0.writeBlock(blkaddr,blkdata)
                 elecounter += 1
              wait_ms(400)
              # read data only for debug
              inputstr1 = rfid_0.readBlockStr(1)
              inputsrt2 = rfid_0.readBlockStr(2)
              inputstr4 = rfid_0.readBlockStr(4)
              # all data stored on tag
              for blkcount in range (0,elecounter):
                  blkaddr = validptr[blkcount]
                  record = rfid_0.readBlockStr(blkaddr)
                  alldata += record
              if inputdata == '1e1cb67cc8':
                power.setVibrationIntensity(80)
                power.setVibrationEnable(True)
                wait(0.5)
                power.setVibrationEnable(False)
              # show data for debug and validation
              text_1.set_text(str(inputstr1))
              text_2.set_text(str(inputsrt2))
              text_4.set_text(str(inputstr4))
              alldata_label.set_text(str(alldata))
              wait(2)
