Cat-M or CatM+GNSS Unit not working in UIFLOW - screen stays blank - [solved]
Hi all,
i ordered a bunch of units to try out some things.When i connect the Cat-M or the CatM+GNSS to my Core2 oder StickCPlus it does not work with UIFLOW
For testing, i added a Label to the screen. When i push it to the device, the label shows.
Then i add the Unit. E.g. the Cat-M Modul to the device, in UIFLOW and connect the cable.
When i push the code to the device ( no additional Blocks added yet, just defined the Unit ), the screen stays blank, and the label is not displayed.This behaviour is the same for the Cat-M unit, or the CatM+GNSS Unit.
Any ideas what might be wrong? I have connected the Core2 via usb to a additional power source, just to be sure.
I am talking about this two units:
https://shop.m5stack.com/collections/m5-sensor/products/sim7080g-cat-m-nb-iot-unit
or
https://shop.m5stack.com/collections/m5-sensor/products/sim7080g-cat-m-nb-iot-gnss-unit-with-telec-antenna
Hello @a1development
I think I know what might be going on. As part of the initialization the UIFlow code sends the AT command to check for a SIM PIN, e.g.
AT+CPIN?
and if it doesn't receive a+CPIN: READY
it won't continue.Make sure you have a IoT SIM card in your Cat-M unit which has the SIM PIN disabled.
Most of the time, if i wait about 5 minutes it works. It seems to be an initialization issue.
Thank you all for your help.
I removed the pin from my sim card and now it works :)
I am glad to hear you got it working and thank you for reporting back.
