    'module' object has not attribute 'ENV3'
    UIFlow
    3.0k
    • G
      guymanuel
      I'm using UIFlow to read a temperature from the ENV3 hat connected to a StickC, but am consistently getting the above error on the screen. The code is:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      import hat
      setScreenColor(0x111111)
      hat_env3_4 = hat.get(hat.ENV3)
      label0 = M5TextBox(16, 37, "label0", lcd.FONT_Default, 0xFFFFFF, rotate=0)
      while True:
      label0.setText(str(hat_env3_4.temperature))
      What can be causing this?
        Hello @guymanuel
        which UIFlow firmware version is installed on your M5StickC?
        One possible cause I know for this error is a too old UIFlow firmware version running on your M5StickC. I can provoke this error when I load UIFlow firmware version 1.7.5 onto my M5StickC. Newer UIFlow firmware versions seem to be ok.
