    Cat-M1 + GNSS Unit has no GPS GNSS option.
    Units
    6.1k
    • H
      HWTaro9
      According to the docs page the Cat-M1 + GNSS unit supports GPS, but in UiFlow the only options are GLONASS (Russia), BEIDOU (China), GALILEAN (Europe), and QZSS (Japan), and I'm in the US and I need to use GPS.
        Hello @HWTaro9
        I think you can choose any of the four options as GPS is always included by default. From the SIM7080 AT command document:
        AT+SGNSCFG="MODE",<mode>
        0 start GPS and GLONASS constellation
        1 start GPS and GALILEO constellation
        2 start GPS and BEIDOU constellation
        3 start GPS and QZSS constellation
        • H
          HWTaro9 @felmue
          @felmue Thanks! so if I don't use the block that sets what constellation it uses, it will default to just using GPS, right?
            Hello @HWTaro9
            I just ran below three blocks and monitored the AT commands they would send to the modem (w/o the modem actually stacked / connected to the M5Stack):
            GNSS power control 'on' -> AT+CGNSPWR=1
            GNSS work mode 'GLONASS' -> AT+CGNSMOD=1,1,0,0,0
            GNSS NMEA poll task -> AT+CGNSINF
            This means that the AT command AT+SGNSCFG=<MODE> I mentioned before is not part of these three blocks.
            BTW: checking the work mode on my SIM7080 for the first time returns:
            AT+CGNSMOD?
            +CGNSMOD: 1,1,0,0,0
            which means GPS and GLONASS are enabled. And since this command's parameter saving mode is AUTO_SAVE_REBOOT I would assume that this is the default.
            In other words if you omit the work mode block I'd assume GPS and GLONASS are enabled by default.
            • H
              HWTaro9 @felmue
              @felmue Thank you very much!
