    M5 CORE INK
    PROJECTS
    m5 core ink
    3.1k
    • B
      BM22
      Hello Everyone,
      Hope my question is in the right section, if not please let me know, thanks!
      I got a M5 CORE INK and i want connect it with an encoder (360PPR). The goal is to be able to read the value of an angle (in degree)
      Here an example of what i want to do: https://www.youtube.com/watch?v=jN9B3y1iPeA&ab_channel=JpbBricole-
      I'm a real beginer in code, i use Arduino IDE.
      My problem is about how to put the value of the angle on the Core Ink screen's
      Currently, my code work with a visualization on the serial monitorbut i don't know how to push it on the Core Ink screen's
      Here my code:
      /* Encoder Library - Basic Example
      • http://www.pjrc.com/teensy/td_libs_Encoder.html
      • This example code is in the public domain.
      #include <Encoder.h>
      // Change these two numbers to the pins connected to your encoder.
      // Best Performance: both pins have interrupt capability
      // Good Performance: only the first pin has interrupt capability
      // Low Performance: neither pin has interrupt capability
      Encoder myEnc(25, 26);
      // avoid using pins with LEDs attached
      int newPosition;
      float angle;
      Serial.begin(9600);
      Serial.println("Basic Encoder Test:");
      long oldPosition = -999;
      long newPosition = myEnc.read();
      if (newPosition != oldPosition) {
      oldPosition = newPosition;
      angle = newPosition * 0.005;
      Serial.println(angle);
      I want also put a reset function.
      BM22
        Hello @BM22
        have a look at this example. It shows how to put 'Hello World!' onto the M5CoreInk screen.
