Antenna Rotor Control
Hello everybody,
I am approaching this interesting system today.
I would like to make a small portable antenna rotor that I can control with M5stack.
I need to be able to visualize the position in order to calculate the degrees and insert keys to make it rotate in both directions from -15 ° to 360 + 15 °
I am wondering what kind of motor to use also to be able to adjust the rotation speed around 1RPM.
Also if you have two tips on how to set up the logic.
Thank you
