    CoreInk example does not compile
    3 Posts 2 Posters 4.1k Views
      aafortinet
      I have a M5-CoreInk and am trying out the example source code provided in the docs.
      When I compile the source code with Arduino, I get the following error. Probably an issue with my setup. Can you please help me?
      Arduino: 1.8.19 (Linux), Board: "M5Stack-CoreInk, Default, 921600, None"
      /home/axelle/Arduino/libraries/M5-CoreInk/src/M5CoreInk.cpp: In member function 'int M5CoreInk::begin(bool, bool, bool)':
      /home/axelle/Arduino/libraries/M5-CoreInk/src/M5CoreInk.cpp:23:33: error: call of overloaded 'begin(int, int, int)' is ambiguous
               Wire.begin(32, 33, 10000);
      In file included from /home/axelle/Arduino/libraries/M5-CoreInk/src/utility/BM8563.h:4,
                       from /home/axelle/Arduino/libraries/M5-CoreInk/src/M5CoreInk.h:8,
                       from /home/axelle/Arduino/libraries/M5-CoreInk/src/M5CoreInk.cpp:1:
      /home/axelle/.arduino15/packages/m5stack/hardware/esp32/2.0.2/libraries/Wire/src/Wire.h:79:10: note: candidate: 'bool TwoWire::begin(int, int, uint32_t)'
           bool begin(int sda=-1, int scl=-1, uint32_t frequency=0); // returns true, if successful init of i2c bus
      /home/axelle/.arduino15/packages/m5stack/hardware/esp32/2.0.2/libraries/Wire/src/Wire.h:80:10: note: candidate: 'bool TwoWire::begin(uint8_t, int, int, uint32_t)'
           bool begin(uint8_t slaveAddr, int sda=-1, int scl=-1, uint32_t frequency=0);
      exit status 1
      Error compiling for board M5Stack-CoreInk.
      • I have added the libraries M5-CoreInk 0.0.2, M5GFX 0.0.17 and M5Unified 0.0.4 (not sure if I need the last 2).
      • I have added the board manager https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/arduino/package_m5stack_index.json
      • My selected board is M5Stack-CoreInk
      • My CoreInk seems to be functioning correctly, currently I have the UIFlow screen on it with the API Key.
      Note anyway that the issue is with compiling the code. I haven't even gone past that step to push it on the device.
      • felmueF Online
        Hello @aafortinet
        download the latest version of the M5CoreInk library. This bug has been fixed here.
          aafortinet @felmue
          @felmue thanks! It works fine after the update :)
