    Com.X.LoraWan 868 module configured at 470Mhz ?
    4 Posts 2 Posters 5.4k Views
    • E Offline
      ecasti
      HI All,
      just bought the module COM.LoRaWAN 868 and I'm trying to configuring as Lora to test communication with a different module i got.
      When i try to configure the frequency, I got error "+ERROR: the command is not supported"
      I'm trying with:
      • ATCommand("FREQ", "868000000");
      • ATCommand("LoraPara", "868000000,18,12,0,1,8,1,0,0");
        and I get the same error.
        Then I tried to inquire about current setting and I get on reset::
      16:21:56.550 -> AT Rev 1.3
      16:21:56.550 -> +AutoLPM=0
      16:21:56.550 ->
      16:21:56.550 -> +LORAWAN=0
      16:21:56.550 ->
      16:21:56.550 -> +FREQ=470000000
      16:21:56.550 -> +TxPower=10
      16:21:56.550 -> +SF=7
      16:21:56.550 -> +BW=0
      16:21:56.550 -> +Coderate=1
      16:21:56.550 -> +Preamblelth=8
      16:21:56.550 -> +CRC=1
      16:21:56.550 -> +IQInvert=0
      and by issuing " ATCommand("LoraSet", "?");"
      16:21:59.708 -> +LoraPara:470000000,10,7,0,1,8,1,0
      If i check on the chip CubeCell, below the logo it show 863-870
      Is there anything wrong on my module?
      • felmueF Online
        Hello @ecasti
        no, I don't think there is anything wrong with your module. My two modules report the same firmware version 1.3 as yours and the same frequency (470000000) is returned when uninitialized. I also get the same error (not supported) when trying to set the frequency via FREQ. I think the documentation doesn't 100% match the firmware installed on the module.
        I am using below command to setup LoRa parameters for a point to point connection:
          ATCommand("LoraSet", "868000000,18,12,0,1,8,1,0,0");
        • E Offline
          ecasti
          @felmue said in Com.X.LoraWan 868 module configured at 470Mhz ?:
          LoraSet
          Thanks a lot, Felix,
          it works !
          Will try to find more details about this firmware to drop some note here.
          Happy New Year
          • felmueF Online
            Hello @ecasti
            glad to hear you got it working and thank you for reporting back.
            Happy New Year!
