    Brightness on m5stickc & core gray?
    Micropython
    4.4k
    • D
      dclaar
      On the m5stickc, uiflow's brightness is converted to axp.setLcdBrightness(level). This appears to be between 0 and 100, although 20 is barely visible in the dark.
      The core gray doesn't have axp, but one can use lcd.setBrightness(level): This appears to be 0-255 from the doc, but realistically, it doesn't seem to matter above 25 or so. Is this documented anywhere?
        Hello @dclaar
        I don't think this has been documented yet - but I could be wrong.
        But consider this. I have multiple M5Stack (Gray, Basic, Fire) and even with the same brightness setting the actual brightness differs visibly.
