Serial2 Don't compile
I have recently changed to using https://dl.espressif.com/dl/package_esp32_index.json in the boards manager now any application using serial2 wont comple. I get an error Error compiling for board M5Stack-Core-ESP32.
David Ardis
@ardisd Can you post a screenshot of the error ouput from arduino?
Enclosed screen shot as requested
I get the same error when compiling Serial2.ino and my own code
Are you running arduino 1.8.7?
Thats not all the error.
Upgraded to 1.8.7 was on 1.8.5
This is the error now
I first thought is to tell you to Backup and delete the SD folders in dropbox and
C:\programfiles(x86)\Arduino\Librarys\SD
and then try again.Can I see your source code?
Just the standard serial2 sketch
#include <M5Stack.h>
HardwareSerial Serial2(2);
Serial.begin(115200);
// Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
Serial2.begin(115200, SERIAL_8N1, 16, 17);
}void loop() {
if(Serial.available()) {
int ch = Serial.read();
Serial2.write(ch);
}if(Serial2.available()) {
int ch = Serial2.read();
Serial.write(ch);
I got the same problem.
I changed the rename of Serial2 and fixed it.HardwareSerial Serial2(2);
→HardwareSerial Serial2_(2);
