    Product failed. Burning, Downloading, finding where to get API get.
    Core 2
    15.1k
    • E
      Edawen
      I had bought the M5Stack Core2 on a whim from Amazon and found out too late it would not work to send it back.
      At first, when running UIFlow, I was prompted for an API key. For some reason that stopped. I was never able to find where to get one, but one of the introductory videos hinted at running M5Burner which I did.
      I can never get this program to succeed in Erasing or Burning firmware from the Core2. I have the CP210x driver installed from working with Arduino Minis or Micros (or something), but I installed the provided driver just to make sure I was using a current version. In Device Manager the message I see is "Silicon Labs CP210x USB to UART Bridge (COM8)".
      When doing an erase i see
      Erase now
      esptool.py v2.5.0
      Serial port COM8
      Connecting........_____....._____....._____....._____....._____....._____....._____
      A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header
       Erase Failed
      When I do a burn of firmware
      Start Burn
      --chip esp32 --port COM8 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x7ff000 C:\Users\Owner\Downloads\M5Stack\M5Burner\packages\fw\other\wifi.bin 0x1000 C:\Users\Owner\Downloads\M5Stack\M5Burner\packages\fw\core\UIFlow_Core2-v1.8.4-core2.bin
      esptool.py v2.5.0
      Serial port COM8
      Connecting...
      [ I have removed some of the dots and dashes for brevity ]
      _
      _
      A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
       Burn Failed
      In both cases the Core2 or M5PAPER reboots once the error is complete.
      I am a VA with memory damage and had forgotten that I had purchased a M5Core2 and not been able to get it to work after the Amazon return period had passed, I just recently purchased the M5PAPER, a M5 CORE INK and an M5 STICK C PLUS.
      I tried downloading to the M5 STICK C PLUS and it worked fine, giving me the API key, then i downloaded one of the demos and it worked fine.
      The M5 CORE INK failed in the same manner as the other two.
      So, any ideas ? Which straw do I grasp at first ?
      Regards, mark.
        Hi, Adam here.
        This is not an issue with the m5stack devices but is a known issue with the host computer and the driver.
        There is a known conflict in both windows and OSX where there is an existing driver preinstalled which corrupts the installation of the the new driver.
        Have you shut the computer down after installing the driver and restarted the computer afterwards?
        Search the forum for the "Cold Boot Method"
        The API number should be shown on the screen once the wifi setup on the device is complete.
        Here is my work in progress book https://github.com/Ajb2k3/UIFlowHandbook/blob/master/quickblockref.pdf that should be able to help you.
        E 1 Reply Last reply Reply Quote 1
        • OyczEO
          OyczE
          Hey @Edawen
          bit strange, what about open COM8 via putty the is any output ?
          In case on Core2 please open it and disconnect internal battery and try again.
          But more or less this could be a service tickate case.
          • E
            Edawen @OyczE
            @mati said in Product failed. Burning, Downloading, finding where to get API get.:
            a
            Putty doesnt do any good. I did find, by accident, that if i went into monitor, and pressed Reset instead of Send, it would print out this ;
            COM8
            ets Jul 29 2019 12:21:46
            rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
            configsip: 0, SPIWP:0xee
            mode:DIO, clock div:1
            load:0x3fff0018,len:4
            load:0x3fff001c,len:1044
            load:0x40078000,len:8896
            load:0x40080400,len:5816
            entry 0x400806ac
            entry 0x400806ac
            M5Core2 initializing...axp: vbus limit off
            axp: gpio1 init
            axp: gpio2 init
            axp: rtc battery charging enabled
            axp: esp32 power voltage was set to 3.35v
            axp: lcd backlight voltage was set to 2.80v
            axp: lcd logic and sdcard voltage preset to 3.3v
            axp: vibrator voltage preset to 2v
            [E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(3)
            OK
            Addr:0x34 - Name:Axp192
            I2C Axp192 Found
            Addr:0x38 - Name:CST Touch
            I2C CST Touch Found
            Addr:0x68 - Name:IMU6886
            I2C IMU6886 Found
            Addr:0x51 - Name:BM8563
            I2C BM8563 Found
            I'm not sure what to Send, in monitor or Putty. This doesn't show up in Putty, as text or as garbage. There is no SD card inserted and it is at the red "SDCard Find failed" prompt on the Core2.
            This is after I shutdown the PC, removed and deleted the driver and installed CP210xVCPInstaller_x64_v6.7.0.0, the same driver installed bu UIflow. M5Burner will still not work. I have not followed the Cold Start Method yet. That will be tomorrow.
            Regards.
            • E
              Edawen @ajb2k3
              @ajb2k3 I searched for ""Cold Boot Method" and only found 4 references, the oldest 8 months ago, none were helpful.
              I took a guess and cold started my computer, removed the old driver, deleting the driver and then installing the driver installed by UIFlow, CP210xVCPInstaller_x64_v6.7.0.0. That did not fix the problem.
              I searched the forum a bit and I think I found your method here; https://community.m5stack.com/topic/2303/solved-arduino-ide-on-windows-won-t-flash
              I will try it tomorrow when I am more awake.
              Thank you for the link to your WIP book,, I am glad to see you have a section on ESP NOW. Do you cover Deep Sleep and power saving modes (and ULP) ?
              Regards.
                ajb2k3 @Edawen
                @edawen
                Thanks, I am having setup issues at the moment myself with the M5Stamp that is driving me crazy.
                Deepsleep and power saving modes are yet to be worked on because I keep getting distracted.
                • OyczEO
                  OyczE @Edawen
                  @edawen said in Product failed. Burning, Downloading, finding where to get API get.:
                  a
                  COM8
                  entry 0x400806ac
                  entry 0x400806ac
                  axp: gpio1 init
                  axp: gpio2 init
                  OK
                  I2C Axp192 Found
                  I2C CST Touch Found
                  I2C IMU6886 Found
                  I2C BM8563 Found
                  Regards.
                  this proof there is a communication, with is fine but core2 is in the boot loop.
                  What about opening or to be more precision remove bottom where is a battery.
                  After opening inspect both buttons maybe one stuck and this is a problem with loop.
                  • OyczEO
                    OyczE
                    ahh one more think with i just recall :D
                    when my core 2 was at home by using M5Burner by mistake i just preload UIflow for Core not for Core2 and this was a same loop as you can see
