    REMOTE+ Slider for motors
    UIFlow
    11
    18.5k
      you need to use the map block to map the range
      • W
        Werner_G
        you are probably right. But I cannot see any similarity with the maps-function of other IDE's. Great would be a mathematical function like this from MakeCode:
        "map 'speed' from low '0' high '100' to low '-127' high '127'" (or vice versa)
        Using arrays is very compicated, too much for me.
        • R
          robalstona
          def translate(value, inMin, inMax, outMin, outMax):
              return (value - inMin) * (outMax - outMin) / (inMax - inMin) + outMin
          • W
            Werner_G
            Thank you. I tried this:
            def slider_Motor_callback(slider_value):
            global inMin, inMax, outMin, outMax, tof_0
            motion = Motion()
            inMin = 0
            inMax = 100
            outMin = -127
            outMax = 127
            def translate(slider_value, inMin, inMax, outMin, outMax):
            return (slider_value - inMin) * (outMax - outMin) / (inMax - inMin) + outMin
            motion.set_motor_speed(1, slider_value)
            But this doesn't work. What might be wrong?
            • J
              joueurgear
              the definition of your function has been created but you have to call it now with :
              • W
                Werner_G
                I also tried this - but with no success. Seems that mapping or translating might not work in combination with REMOTE. Thanks for your help!
                • R
                  robalstona
                  Try this:
                    motion = Motion()
                    motion.set_motor_speed(1, translate(slider_value, 0, 100, -127, 127) )
                  • W
                    Werner_G @robalstona
                    @robalstona
                    with this definition the motors shows absolutely no movement.
                    • R
                      robalstona
                      @Werner_G, probably there is a problem with remote control. In this thread is a post about it
                      https://community.m5stack.com/topic/3477/uiflow-1-8-1
                      • W
                        Werner_G
                        Finally, I've got it working using the map-block from Easy I/O in UIFlow (by chance I found it!), which is just
                        motion.set_motor_speed(2, map_value(slider_value, 0, 100, -127, 127))
                        without any translation. Works fine with Remote+
