    Connect DS18B20 to Grove Port A?
    PROJECTS
    8.8k
    • C
      critter
      has anyone been able to connect a 1 wire ds18b20 waterproof temperature sensor to the m5stack grove connector A?
      I see a + and a - port, and an SDA and an SCL port. Can either of those be used to one wire connections? And how would I do that in code?
      Thank you so much!
      Christian
      • R
        robalstona
        I made custom block for uiflow for do this. But i implemented use only one sensor per gpio pin without checking crc errors (shorter and simplicity code).
        https://github.com/stonatm/UiFlow-custom-blocks/tree/master/ds18b20
        and here is python code used in this custom block:
        https://github.com/stonatm/M5Atom_matrix_library/blob/master/lib/dallas.py
        Try connect sensor to SDA pin in groove port, but you must find a number of gpio pin assigned for this line.
        You also should connect a pullup resistor (2-10kohm) betwen sensor DQ pin and sensor Vcc. In my case i use ds18b20 without this resistor, but my connection to sensor is shorter than 10cm.
        • C
          critter
          I've connected a DS1820 waterproof sensor to the Grove / Port A of the M5basic
          GND=black
          VCC=red
          SDA=yellow
          My code is :
          #include <M5Stack.h>
          #include <OneWire.h>
          #include <DallasTemperature.h>
          #define ONE_WIRE_BUS XX
          OneWire oneWire(ONE_WIRE_BUS);
          DallasTemperature sensors(&oneWire);
          void setup(){
          M5.Power.begin();
          M5.Lcd.print("onewire temp test");
          sensors.requestTemperatures();
          String text = String(sensors.getTempCByIndex(0),2)+"C";
          M5.Lcd.println(text);
          delay(800);
          M5.Lcd.println("test");
          for XX, I've tried port 21,22,32,33 and a few other I read rumours about. No success to read the temperature so far. Any clue?
          • C
            critter
            All right, to answer my own post :
            This post helped a lot :
            https://community.m5stack.com/topic/1086/problem-when-connecting-more-than-3-ds18b20-temperature-sensors-solved/6
            And XX is 21.
            • grelmG
              grelm
              I am happy to read that the post was helpful.
              Which changes did you apply to make it work?
              Programming M5Stack Fire with Arduino for Home Automation
