    TVOC/Co2 Uiflow Problem
    2 Posts 2 Posters 3.5k Views
      aek56
      Hi there
      The newly introduced Uiflow for TVOC does not work properly, it does not give me any CO2 and TVOC back, does all the time reports 400/0. Works without any problem in Arduino.
      Can you please have a look at ? Would be a benefit for me to use it thru Uiflow.
      Thanks and Regards
      aek56
        pierre.halleux
        Same here.
        I tried this and this keep displyaing eCO2 400...
        Any idea?
        from m5stack import *
        from m5ui import *
        from uiflow import *
        import unit
        setScreenColor(0x111111)
        tvoc0 = unit.get(unit.TVOC, unit.PORTA)
        CVO = None
        MAX = None
        H2T = M5TextBox(53, 19, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        H2 = M5TextBox(0, 19, "H2", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        BT = M5TextBox(21, 48, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        TVOCT = M5TextBox(63, 80, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        BTVOCT = M5TextBox(72, 112, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        eco2T = M5TextBox(63, 136, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        B = M5TextBox(0, 48, "B.", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        TVOC = M5TextBox(0, 80, "TVOC", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        BTVOC = M5TextBox(0, 112, "B. TVOC", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        eCO2 = M5TextBox(0, 136, "eCO2", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        Ethanol = M5TextBox(0, 173, "Ethanol", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        EthanolT = M5TextBox(62, 173, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        MAX = 1400
        tvoc0.set_iaq_baseline(35187, 35502)
        while True:
        H2T.setText(str(tvoc0.H2))
        BT.setText(str(tvoc0.get_iaq_baseline()))
        TVOCT.setText(str(tvoc0.TVOC))
        BTVOCT.setText(str(tvoc0.baseline_TVOC))
        eco2T.setText(str(tvoc0.eCO2))
        EthanolT.setText(str(tvoc0.Ethanol))
        if (tvoc0.eCO2) > MAX:
        M5Led.on()
        speaker.sing(196, 1/2)
        M5Led.off()
        wait_ms(2)
