    I want to communicate data with M5stack Core2 and COM.Sigfox.
    Modules
    core2 sigfox
    16.4k
    • T
      takero
      Hello. I bought M5stack Core2 and COM.Sigfox. I want to use this for data communication.
      I was able to register the module in the sigfox backend. But I can't communicate or call back.
      When I use M5stack Basic and COM.Sigfox,I can do data communication and callbacks.
      Is there something wrong with my sketch?
      #include <M5Core2.h>
       M5.begin(true, false, true);
       Serial2.begin(9600, SERIAL_8N1, 13, 14);
       Serial.begin(9600);
       int val = 11223344;
       String msg = String(val, HEX);
       Serial.print( msg);  Serial.println(" msg ");
       Serial2.print("AT$SF=" + msg);
       Serial.print("AT$SF=" + msg);  Serial.println(" AT$SF= msg ");
       delay(15*1000);
        Hello @takero
        in this example sending a command uses Serial2.write("AT$SF=00FFEE\r\n"); instead of print(). In another example I found println() was used.
        I have a feeling the COM.Sigfox module would like a \r\n as a line end. (But that is just a guess as I don't have that module and cannot test myself.)
        Good luck!
        • T
          takero @felmue
          Thank you for suggestion Felix. And Sorry for my late reply.
          I tried Serial2.println("AT$SF=" + msg );.
          or Serial2.println("AT$SF= + msg ");.
          and Serial2.write("AT$SF= + msg ");.
          or Serial2.write("AT$SF=" + msg );.
          But I couldn't communicate.
          If you have new tips, I would love to try.
          Thank you.
            Hello @takero
            have you tried the example I've mentioned? This should read and display the SigfoxID and PACNumber and if successful would tell you the hardware is ok.
            Note: for M5Core2 you'll need to adapt rxPin to 13 and txPin to 14 as before.
            • T
              takero @felmue
              @felmue Thank you.
              I tried your sample. I succeeded in compiling.
              But I can't write to core2 since yesterday.
              Displayed "A fatal error occurred: Failed to connect to ESP32: Timed out Waiting for packet header"
              Both of the Core2 I have are like that. Did my Core 2 break?
              I just wrote a sketch.
              Thank you.
                Hello @takero
                sorry to hear. It's very unlikely that both of your M5Core2 devices just broke like that. Some suggestions:
                • Have you tried a different USB cable?
                • Have you tried a different USB port?
                • Have you tried closing and reopening your software?
                • Have you tried to reboot your computer?
                • T
                  takero @felmue
                  Thank you @felmue .I have tried your suggestion.
                  Have you tried a different USB cable? :Yes I did.
                  Have you tried a different USB port? :Yes I did.
                  Have you tried closing and reopening your software? :Yes I did.
                  Have you tried to reboot your computer? :Yes I did.
                  However, I got an error. Isn't my Core 2 broken ?
                  I tried another sketch and the result was the same.
                  At that time, I connected the actual sensor.
                  DHT22 to GPIO72.
                  DS18B20 to GPIO26.
                  Analog sensor to GPIO36.
                  Is that not good?
                  Thank you.
                    Hello @takero
                    until you have figured out the issue regarding flashing a sketch (any sketch) onto your M5Core2, I'd do the following:
                    • only connect the USB cable to your computer
                    • disconnect everything else
                    • try flashing a sketch
                      If that doesn't work, then maybe your M5Core2 has been damaged (still very unlikely though).
                    • T
                      takero @felmue
                      While I was writing to Core 2, I pressed the power button for a long time and the writing was successful.
                      Thank you.
