    Help to upgrade battery without any accessory for RGBW lamp project
    M5 Stick/StickC
    9.0k
    • A
      akshaypatil
      I'm designing a battery-powered lamp for tables with M5StickC and,
      1. Can I replace the 80mah lipo with a 3300mah? (I don't want to use the battery HAT)
      2. How do I disassemble M5stickC beyond the 2 screws? (It's not easy to lift the board and get access to the battery.)
      3. Are there libraries to program RGBW neopixels for UIFLOW?(https://www.adafruit.com/product/2858)
      Thank you!
        Hello @akshaypatil
        1. what exactly do you mean by 'replace'? You can 'attach/add' any battery on the outside, but almost any larger capacity battery will not mechanically fit inside M5StickC.
        2. AFAIK you cannot lift the two boards without separating them first - that is what I did when I took these pictures.
        3. I don't know.
        Cheers
          all you need to do is connect 5V directly to the led strip between the M5StickC and the led strip.
          alt text
          • A
            akshaypatil @felmue
            @felmue Thank you! Sorry for the late reply, got busy with something.
            Which ports do I add the battery externally? To "bat" and "gnd"?
            I was going to leave it barebones since it's not easy to find an alternative esp32 pico kit with a battery charging circuit onboard. (tiny tiny size)
            Would be cool to have an esp32 mounted on top of a li-ion cell, like how they have the protection circuits.
              Hello @akshaypatil
              yes, 'bat' and 'gnd'. I suggest you also check out the M5StickC schematics.
              Cheers
