M5StickC-Plus is dead?
Hi, I have a M5StickC-Plus,
I connected it to my computer, tried the basic example "display", it worked fine. After that I moved to an example to display only text, everything was fine.30 minutes or one hour later, I couldn't upload code to the device. Arduino IDE says
"A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header"
If I connect or disconnect the device appears or disappears from the ports list.
But I can't upload code and the device doesn't do anything.
Do you have some suggestions?
My stick c plus died just after 2 days during a sketch uplod .
@ashmumblejumble said in M5StickC-Plus is dead?:
Have you tried this procedure?
https://community.m5stack.com/topic/1464/m5stickc-screen-don-t-work/8
