USB Module is useless
USB Module with MAX3421E is useless without an UIFlow integration, please fix.
Not everyone uses UIFlow ;-)
It also can't be integrated with micropython :(
@mtal said in USB Module is useless:
MAX3421E
Hi, Currently the module only support Arduino IDE, it might support more features in the future. you can check the documentation before your purchase to see which functions are supported and which are not. the unsupported programming language has nothing to do with the module itself being so called "useless".
@zontex You are selling a modular solution, and one of the modules is not compatible with the others, so yes, it is useless.
@mtal M5Stack have different core modules with different extension and support, not all the modules are compatible with each other. for example, we have some modules for Core2 and some for ATOM but not all the modules for Core2 can work with ATOM.
The USB Module specifically is not compatible with all the Core modules and in all the programming frameworks, you can find more information about compatibility and the modules on our documentation.
