LAN module problem
The LAN W5500 demo program for Arduino is not working.
Any solution ? -
Hello @meirmark
sorry to hear about your troubles. Could you please provide some additional information about your setup?
- Which M5Stack device are you using? M5Stack (Base, Gray, Fire) or M5Core2?
 - How are you powering your setup? Through USB or through the power connector of the LAN W5500 base?
 - What exactly isn't working? Is there a problem with compiling the code? Downloading the code? Running the code?
 - Any error message?
 - What is your development environment? Arduino IDE or VS Code / PlatformIO?
 - And lastly, could you post your code?
Felix -
I work with the Arduino IDE.
The Error is: cannot declare variable 'server' to be of abstract type 'EthernetServer'
I found a by-pass that solve the problem by changing the "cores/esp32/Server.h" file .
it works but it makes a new problem for other programs that use WiFi.
Is there a real solution ? -
Hello @meirmark
hmm, that doesn't sound right. Which Ethernet library are you using?
When I was testing Ethernet last I used the
Ethernet2library as suggested in the web server example:/** * Web Server * Need to install Ethernet2 arduino library * Please don`t install it by arduino library manange * If install, delete it * Ethernet2 file in M5stack lib examples -> modules -> W5500 -> Ethernet2.zip */You'll find it here.
Felix -
According to Arduino site ,the new Ethernet lib can work with the W5500 chip so no need the Ethernet2 lib.
Link: https://www.arduino.cc/en/Reference/EthernetI tested also with the Ethernet2 lib from the ESP32 and it works.
Thanks.
This code is tested and work fine. 1 jan 2021
- projet SWID_M5 ( Switch ID pour M5Stack)
version 0.3date debut : 1 aout 2020
MODIF : 2 aout 2020
modif : 16-18 dec 2020 modif ethernet2 serveur tester et fonctionnel
programmation: Francois Blais Montreal QC
capture de trame pour la decouverte de commutateur (lldp)
materiels
M5stack core 4meg prog 1.2 meg ram
ecran affichage avec un OLED integer au bibli m5stack (esp32) M5.LCD.println();
3 bouton
1 haut parleurmodule battery
module lan_w5500 ethernet2.h rj45bibliotheques
chemin de bibli shield w5500 lecture en mode raw C:\Users\fblai\Documents\Arduino\libraries\Ethernet\src\utility
problèmes constatés
1- bibliotherque doit etre celle fournie par m5stack dans la section module/w5500 sinon erreur manque var
2- pour utiliser le serveur test de m5stack dans la section module/w5500 il faut prendre ladresse 192.168.0.177 pour ce conformer a la plage disponible sur mon routeur
3- il faut serrer les trois modules car probleme de connection physique sinon led power clignote
4- il faut mettre dans le w5500.init(CS) qui est CS=26 au lieu de celui par defaut qui est 10
5- utilisation des socket a partir de lobjet w5500.execCmdSn(s,sock_open ou close ou recv )utilisation de m5stack
bouton de power sur le coté
peser une fois sur le power pour le demarrer ou le reinitialier
peser 2 fois sur le power pour le fermer==================================================== */
bibli
==================================================== */#include <M5Stack.h>
//------------------- ethernet2 w5500 lan rj45
#include <SPI.h>
#include <Ethernet2.h>
#include <utility/w5500.h> // doit etre sous <Ethernet2.h>#define SCK 18 // adaptation pour m5stack
#define MISO 19
#define MOSI 23
#define CS 26// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network: FB:AD:BE:EF:FE:FB 192.168.0.177
byte mac[] = {
0xFB, 0xAD, 0xBE, 0xEF, 0xFE, 0xFB
};SOCKET s; // RAW mode
int rbuflen ;
byte trame[335];
int NBR = 0;
int position[12];/* ====================================================
affichage
==================================================== */String LCD_data[7];
void presentation(String L1,String L2,String L3,String L4,String L5,String L6,String L7,String L8){
M5.Lcd.clear();
M5.Lcd.setCursor(70, 20, 4);
M5.Lcd.println(L1);
M5.Lcd.setCursor(70, 60, 4);
M5.Lcd.println(L2);
M5.Lcd.setCursor(70, 80, 4);
M5.Lcd.println(L3);
M5.Lcd.setCursor(70, 100, 4);
M5.Lcd.println(L4);
M5.Lcd.setCursor(70, 120, 4);
M5.Lcd.println(L5);
M5.Lcd.setCursor(70, 140, 4);
M5.Lcd.println(L6);
M5.Lcd.setCursor(70, 160, 4);
M5.Lcd.println(L7);
M5.Lcd.setCursor(70, 180, 4);
M5.Lcd.println(L8);
declaration de mes fonctions
==================================================== */bool si_lldp();
void lldp();
String decoupe( unsigned int local );
int trouve( const byte rech[] );
String decoupevlan( unsigned int local );
int* trouvetlv();
String decompte;
void matrame();
String x2i(String monhexa);// ========================================================================================================
// =============== fonctionne au debut du script seulement one shot =======================================
// ========================================================================================================void setup()
Serial.begin(115200);M5.begin(true, false, true); M5.Power.begin(); M5.Lcd.setTextFont(4); M5.Lcd.setCursor(50, 100, 4);// ============ initialise lecran oled ===================
presentation( "SWID-M5 v0.3 " , " " ,"Capteur Ethernet", "" ,"Trame LLDP " ," "," ","F.Blais MTL 2020" );
delay(5000);// ============ initialise ethernet en mode raw brodcast ===================
SPI.begin(SCK, MISO, MOSI, -1);
w5500.init(CS);
w5500.writeSnMR(s, SnMR::MACRAW);
w5500.execCmdSn(s, Sock_OPEN);
// ==================== en boucle continue ==============================================================
void loop()
NBR++;// ===================== info sur la switch =======================
Serial.println(decompte);
rbuflen = w5500.getRXReceivedSize(s);
if(rbuflen>0) { if(rbuflen > sizeof(trame)) rbuflen = sizeof(trame); w5500.recv_data_processing(s, trame, rbuflen); w5500.execCmdSn(s, Sock_RECV);}
decompte = " b:" + String(NBR) + " g:" + String(rbuflen) ;
if ( rbuflen > 0 ) {
if (si_lldp()) {
lldp();
presentation( "" , LCD_data[0],LCD_data[1] ,LCD_data[2] ,LCD_data[3] , LCD_data[4] ,LCD_data[5], LCD_data[6]);
delay(30000);
// ================================== mes fonctions ====================================
// ===============================================================================================void lldp(){
int local=0;
String partie;
trouvetlv();// description
partie = decoupe( position[5] ) ;
LCD_data[1] = partie.substring(1,14);
LCD_data[2] = partie.substring(15,partie.length() );// ==============
// equivalent Unit/port
LCD_data[4] = decoupe(position[4] ) ;
LCD_data[4].trim();// ===============
// equivalent 00-80-c2-01 signature de la ligne vlan pos:187 0x0bfc = 3068
byte vlan[]={0x00,0x80,0xc2,0x01};
local = trouve(vlan);if ( local < 330 )
LCD_data[6] = "Vlan:" + decoupevlan(local) ;
else
LCD_data[6] = " pas Vlan" ;}
bool si_lldp() {if( trame[2] == 1 && trame[3] == 128 && trame[4] == 194 && trame[7] == 14 ) {
matrame();
return true;
else
return false;
void matrame()
for(int x = 0 ; x< 334 ; x++)
Serial.print(trame[x]); Serial.print(" ");
Serial.println("");
Serial.print(trame[x],HEX);
Serial.println("");
// EXTRAIT UN MORCEAU EN HEXA ET LE RENVOI EN STRINGString decoupe( unsigned int local ) {
unsigned int i;
int grandeur = trame[local+1] ;
String texte=" ";
for ( i = ( local + 2 ) ; i < (local + grandeur + 2) ; i++ )
texte += (char)trame[i] ;
return texte;
// EXTRAIT UN MORCEAU EN HEXA ET LE RENVOI EN STRINGString decoupevlan( unsigned int local ) {
unsigned int i;
int grandeur = trame[local-1] ;
grandeur = grandeur - 4 ;String texte ;
for ( i = (local+4) ; i< ( (local+4) + ( grandeur) ) ; i++ )
texte += String(trame[i],HEX);
texte = x2i(texte);
texte.trim();
return texte;
// RECHERCHE UN MORCEAU SPECIFIQUE DANS LA TRAME
int trouve(const byte rech[] ) {
unsigned int i = 0;
for ( i = 0 ; i < 330 ; i++ ) {
if (trame[i] == rech[0])
if( (trame[i+1] == rech[1]) and (trame[i+2] == rech[2]) and (trame[i+3] == rech[3]) )
return i;
return 0;
// trouve les deplacements
int* trouvetlv(){
int nbr;
int pos = 16; position[0]=0; position[1]=16;for ( nbr = 2 ; nbr < 9 ; nbr++ ) {
position[nbr] = ( (pos + 2) + trame[pos+1] ); pos = position[nbr];}
return position ;
String print_ip(const byte a[], unsigned int offset, unsigned int length) {
String ip;
for (unsigned int i = offset; i < offset + length; i++) {
// if(i>offset) Serial.print('.');
// Serial.print(a[i], DEC);
if (i > offset) ip = ip + '.';
ip = ip + String (a[i]);
}return ip;
String print_mac(const byte a[], unsigned int offset, unsigned int length) {
String Mac;LCD_data[1] = "";
for (unsigned int i = offset; i < offset + length; ++i) {if (i > offset) { // LCD_data[1] = LCD_data[1] + Mac + ':'; Mac = Mac + ':'; } if (a[i] < 0x10) { Mac = Mac + '0'; // LCD_data[1] = LCD_data[1] + Mac + '0'; } Mac = Mac + String (a[i], HEX);}
LCD_data[1] = LCD_data[1] + Mac;
return Mac;
// converti hexa vers dec en type string
int x = 0; int nbr;
for(nbr=0 ; nbr < monhexa.length() ; nbr++) {if (monhexa[nbr] >= '0' && monhexa[nbr] <= '9') { x *= 16; x += monhexa[nbr] - '0'; } else if (monhexa[nbr] >= 'A' && monhexa[nbr] <= 'F') { x *= 16; x += (monhexa[nbr] - 'A') + 10; } else if (monhexa[nbr] >= 'a' && monhexa[nbr] <= 'f') { x *= 16; x += (monhexa[nbr] - 'a') + 10; } else break;}
return String(x,DEC);
// ================= fin script =====================================================================================================
// ================= fin script ===================================================================================================== -
This script is tested and work fine. 1 jan 2021
MODIF : 2 aout 2020
materiels
3 bouton
problèmes constatés
bibli
#include <SPI.h>
#define MISO 19
#define MOSI 23
byte mac[] = {
int rbuflen ;
byte trame[335];
int NBR = 0;
affichage
M5.Lcd.clear();
M5.Lcd.println(L1);
M5.Lcd.println(L2);
M5.Lcd.println(L3);
M5.Lcd.println(L4);
M5.Lcd.println(L5);
M5.Lcd.println(L6);
M5.Lcd.println(L7);
M5.Lcd.println(L8);
void lldp();
int* trouvetlv();
String decompte;
void matrame();
w5500.init(CS);
void loop()
if (si_lldp()) {
lldp();
delay(30000);
int local=0;
String partie;
else
matrame();
return true;
else
return false;
void matrame()
Serial.println("");
Serial.println("");
unsigned int i;
String texte=" ";
return texte;
unsigned int i;
texte = x2i(texte);
texte.trim();
return texte;
unsigned int i = 0;
return i;
return 0;
int* trouvetlv(){
int nbr;
return position ;
String ip;
}return ip;
return Mac;
int x = 0; int nbr;
@fblais Thank for this code. I managed to get it running. But I am wondering how on earth I could create a webserver based on this code. Currently I am really in the blind? Thanks for your attention.
@meirmark is there already a real solution? The simple example of Webserver for W5500 as provided by M5Stack gives me the same compilation error using the latest Arduino IDE. Please people from M5Stack : please respond with a working webserver example program. Many thanks.
