    ATOM Lite and ENV.II
    4 Posts 3 Posters 8.5k Views 1 Watching
      regres
      I'm trying to get the working with ENV.II unit using modified sample code from https://github.com/m5stack/M5-ProductExampleCodes/blob/master/Unit/ENVII/Arduino/ENVII/ENVII.ino but I keep getting the "Could not find a valid BMP280 sensor, check wiring!" error.
      I've got the ENV.II working with M5Stack Core, but can't figure out the ATOM Lite.
      The code is as follows:
      #include "M5Atom.h"
      #include <Wire.h>
      #include "Adafruit_Sensor.h"
      #include <Adafruit_BMP280.h>
      #include "SHT3X.h"
      SHT3X sht30;
      Adafruit_BMP280 bme;
      float tmp = 0.0;
      float hum = 0.0;
      float pressure = 0.0;
      void setup()
        M5.begin(true, true, true);
        Wire.begin();
        Serial.println(F("ENV Unit(SHT30 and BMP280) test..."));
        while (!bme.begin(0x76))
          Serial.println("Could not find a valid BMP280 sensor, check wiring!");
        pressure = bme.readPressure();
        if(sht30.get()==0){
          tmp = sht30.cTemp;
          hum = sht30.humidity;
        Serial.printf("Temperature: %2.2f*C  Humidity: %0.2f%%  Pressure: %0.2fPa\r\n", tmp, hum, pressure);
        delay(100);
      Any suggestions would be appreciated,
      Thank you
      • felmueF Online
        Hi @regres
        the Groove connector on M5Atom Lite uses GPIO26 and GPIO32 as SDA and SDL. Try this:
          M5.begin(true, false, true);
          Wire.begin(26, 32);
        Note: second parameter to M5.begin() set to false to disable default I2C initialisation (which uses different GPIOs). Then initialise I2C with desired GPIOs.
          regres @felmue
          Hi @felmue
          Thank you for the advice, the Wire.begin(26, 32) is what I was missing.
          I tired M5.begin(true, false, true) before but, by itself, it didn't make any difference.
          Looks like explicitly specifying I2C pins is the way to go.
          Again, thank you
          regres
          • G Offline
            gavin67890
            I have tried using code above and similar from M5Stack repo. I changed the pin assignments to 19 and 22, which works fine on an alt. setup with Atom Lite, Env I hat, and Atom Mate.
            Using the setup below:
            Atom Matrix
            Env II hat
            Atom Mate
            I get this error and continuous reset loop.
            [ 913][W][Wire.cpp:301] begin(): Bus already started in Master Mode.
            Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
            If I pull out the hat, I get a warning via the code that it is disconnected. I know the origin of this post was from long ago, but I can't think what could be causing it. Is there any difference between Env II unit and Env II hat? Any other thoughts welcome.
