    M5StickCPlus MicrPython power saving
    Micropython
    7.0k
    • W
      WonkoTheSane
      Which MicroPython APIs can help reduce power drain on M5StickCPlus?
      I was unable to get basics to work:
      • lcd.setBrightness(0-100) # didn't change LCD backlight brightnes
      • power.getBatteryLevel() # didn't seam to work
      • No API to turn off wifi mentioned at: https://github.com/m5stack/UIFlow-Code/wiki/Advanced - does this work: wifiCfg.wlan_sta.active(False)
      Are there other APIs to turn on/off parts of device , or to reduce power drain?
      • ZontexZ
        Zontex @WonkoTheSane
        @wonkothesane Hi, Usually what you can do is depends on your task to put your ESP32 device into deep sleep mode which will automatically turn off WiFi and other power consuming devices on top of the Stick-C.
          Hello @WonkoTheSane
          try the following commands:
          from m5stack import *
          import machine
          axp.setLcdBrightness(50) # set LCD backlight brightness
          axp.getBatVoltage() # get battery voltage
          machine.deepsleep(10000) # deep sleep for 10 seconds
          machine.lightsleep(10000) # light sleep for 10 seconds
          about WiFi: I don't know how to turn WiFi off with MircoPython, sorry. Somebody else might have an idea?
          Cheers
          • W
            WonkoTheSane @felmue
            Hi @felmue,
            Unfortunately on my M5StickPlus axp.setLcdBrightness(50) gives an error.
            Maybe it has different MicroPython hardware APIs than your device?
              Hello @WonkoTheSane
              Hmm, did you include the line from m5stack import *?
              I have UIFlow 1.6.6 firmware installed on my M5StickC Plus and use Blockly's Set screen brightness block then switched to the Python tab.
