    Re: I2C slave mode doesn't work for UnitV Stick
    Units
    2.6k
    • T
      TakekazuKATO
      Is this problem already solved?
      I encountered the same problem and found a solution.
      I think this is a mistake in the sample program.
      Although the variable `count' in the function i2c_on_transmit must be global it is interpreted as a local variable.
      I have modified the i2c_on_transmit() as follows.
      def i2c_on_transmit()
        global count
        count = count + 1
        print ("on_transmit, send:", count)
        return count
      Then, it worked well.
