Using G33 analogRead while connected to Wi-Fi
First of all, this is my first post so please let me know if there is problem
So I thought I'd do an analog read with the G33 pin, but it worked fine at first, but when I added the code to do the wifi communication, the G33 analog read always returned 4098.
I searched and found that using ADC2 with analogread during wifi communication always returns 4098, but the G33 pin is ADC1.
I don't know what's wrong, please help!
Hello @dollychun
using GPIO33 as analog input and WiFi works for me. M5Atom is connected to WiFi and I get values from 0 to 4095 from GPIO33. Care to share your code?
Felix -
@felmue Heres my code
#include "M5Atom.h" #include "WiFi.h" int analogIn = 33; const char* ssid = "PatoWiFi"; const char* password = "PatoWifi_Password"; WiFiClient client; void setup() { // put your setup code here, to run once: M5.begin(true, false, true); Serial.begin(115200); pinMode(analogIn, INPUT); WiFi.begin(ssid, password); Serial.print("Connecting to WiFi"); while(WiFi.status()!=WL_CONNECTED) { delay(500); Serial.print("."); } Serial.print("OK"); Serial.print("\r\nWiFi connected\r\nIP address: "); Serial.println(WiFi.localIP()); client.connect("www.someurl.com", 80); Serial.println("sending data to server"); client.println("POST / HTTP/1.1"); client.println("Host: www.someurl.com"); client.println("User-Agent: ESP32/M5Atom"); client.println("Accept */*"); client.println(); unsigned long timeout = millis(); while (client.available() == 0) { if (millis() - timeout > 5000) { Serial.println(">>> Client Timeout !"); client.stop(); } } Serial.println("receiving from remote server"); // not testing 'client.connected()' since we do not need to send data here while (client.available()) { char ch = static_cast<char>(client.read()); Serial.print(ch); } // Close the connection Serial.println(); Serial.println("closing connection"); client.stop(); WiFi.disconnect(); } void loop() { // put your main code here, to run repeatedly: int val = analogRead(analogIn); // Always return 4095 Serial.printf("AnalogRead = %d\n", val); delay(100); } -
Hello @dollychun
Hmm, I am running your code (with my WiFi credentials) on an M5Atom Matrix and reading GPIO33 is fine.
I get
0when GPIO33 is connected to GND and4095when connected to +3.3V and values in between when floating as expected.AnalogRead = 0 AnalogRead = 544 AnalogRead = 16 AnalogRead = 4095Have you confirmed that reading GPIO33 works again if you comment out the WiFi code? Maybe adding that isn't the cause that made reading GPIO33 stop working?
Felix -
@felmue said in Using G33 analogRead while connected to Wi-Fi:
Yes. I have confirmed that it works when I remove the Wifi code...
I will try this with another atom...
