    (SOLVED)M5Stack WIFI Upload file on SD in AP mode
    General
    6.0k
    • C
      cepics
      Hi all I'm looking for a way to upload files on M5Stack SD with M5Stack in Acces point mode....
      Is it possible?
      I tried this but without success ( I know this is not access point mode but it could be a starting point..)
      Connecting ...
      Connected to myWifi Use IP address: 192.168.0.150
      Initializing SD card...Card initialised... file access enabled...
      HTTP server started
      this is the serial monitor output:
      This site can’t be reached192.168.0.150 took too long to respond.
      Try:
      Checking the connection
      Checking the proxy and the firewall
      ERR_CONNECTION_TIMED_OUT
      pc and M5Stack are in the same wifi network..
      I'm in the Arduino ecosistem..
      tnks a lot
      • C
        cepics
        This one work on M5Stack!!!!!
        #include "M5Stack.h"
        #include <WiFi.h>
        #include <WiFiClient.h>
        #include <WebServer.h>
        #define ServerVersion "1.0"
        String webpage = "";
        bool   SD_present = false;
        #include "index.h"  //Web page header file
        WebServer server(80);
        // Setup
        void setup(void) {
          Serial.begin(115200);
          Serial.println();
          Serial.println("Booting Sketch...");
          //ESP32 As access point IP: 192.168.4.1
          WiFi.mode(WIFI_AP); //Access Point mode
          WiFi.softAP("ESPWebServer", "12345678");    //Password length minimum 8 char
          Serial.print(F("Initializing SD card..."));
          if (!SD.begin(TFCARD_CS_PIN, SPI, 40000000)) { // see if the card is present and can be initialised. Wemos SD-Card CS uses D8
            Serial.println(F("Card failed or not present, no SD Card data logging possible..."));
            SD_present = false;
          else
            Serial.println(F("Card initialised... file access enabled..."));
            SD_present = true;
          ///////////////////////////// Server Commands
          server.on("/",         HomePage);
          server.on("/download", File_Download);
          server.on("/upload",   File_Upload);
          server.on("/fupload",  HTTP_POST, []() {
            server.send(200);
          }, handleFileUpload);
          ///////////////////////////// End of Request commands
          server.begin();
          Serial.println("HTTP server started");
        // This routine is executed when you open its IP in browser
        void loop(void) {
          server.handleClient();
          delay(1);
        // All supporting functions from here...
        void HomePage() {
          SendHTML_Header();
          webpage += F("<a href='/download'><button>Download</button></a>");
          webpage += F("<a href='/upload'><button>Upload</button></a>");
          append_page_footer();
          SendHTML_Content();
          SendHTML_Stop(); // Stop is needed because no content length was sent
        void File_Download() { // This gets called twice, the first pass selects the input, the second pass then processes the command line arguments
          if (server.args() > 0 ) { // Arguments were received
            if (server.hasArg("download")) SD_file_download(server.arg(0));
          else SelectInput("Enter filename to download", "download", "download");
        void SD_file_download(String filename) {
          if (SD_present) {
            File download = SD.open("/" + filename);
            if (download) {
              server.sendHeader("Content-Type", "text/text");
              server.sendHeader("Content-Disposition", "attachment; filename=" + filename);
              server.sendHeader("Connection", "close");
              server.streamFile(download, "application/octet-stream");
              download.close();
            } else ReportFileNotPresent("download");
          } else ReportSDNotPresent();
        void File_Upload() {
          append_page_header();
          webpage += F("<h3>Select File to Upload</h3>");
          webpage += F("<FORM action='/fupload' method='post' enctype='multipart/form-data'>");
          webpage += F("<input class='buttons' style='width:40%' type='file' name='fupload' id = 'fupload' value=''><br>");
          webpage += F("<br><button class='buttons' style='width:10%' type='submit'>Upload File</button><br>");
          webpage += F("<a href='/'>[Back]</a><br><br>");
          server.send(200, "text/html", webpage);
        File UploadFile;
        void handleFileUpload() { // upload a new file to the Filing system
          HTTPUpload& uploadfile = server.upload(); // See https://github.com/esp8266/Arduino/tree/master/libraries/ESP8266WebServer/srcv
          // For further information on 'status' structure, there are other reasons such as a failed transfer that could be used
          if (uploadfile.status == UPLOAD_FILE_START)
            String filename = uploadfile.filename;
            if (!filename.startsWith("/")) filename = "/" + filename;
            Serial.print("Upload File Name: "); Serial.println(filename);
            SD.remove(filename);                         // Remove a previous version, otherwise data is appended the file again
            UploadFile = SD.open(filename, FILE_WRITE);  // Open the file for writing in SPIFFS (create it, if doesn't exist)
            filename = String();
          else if (uploadfile.status == UPLOAD_FILE_WRITE)
            if (UploadFile) UploadFile.write(uploadfile.buf, uploadfile.currentSize); // Write the received bytes to the file
          else if (uploadfile.status == UPLOAD_FILE_END)
            if (UploadFile)         // If the file was successfully created
              UploadFile.close();   // Close the file again
              Serial.print("Upload Size: "); Serial.println(uploadfile.totalSize);
              webpage = "";
              webpage += F("<h3>File was successfully uploaded</h3>");
              webpage += F("<h2>Uploaded File Name: "); webpage += uploadfile.filename + "</h2>";
              webpage += F("<h2>File Size: "); webpage += file_size(uploadfile.totalSize) + "</h2><br>";
            else
              ReportCouldNotCreateFile("upload");
        void SendHTML_Header() {
          server.sendHeader("Cache-Control", "no-cache, no-store, must-revalidate");
          server.sendHeader("Pragma", "no-cache");
          server.sendHeader("Expires", "-1");
          server.setContentLength(CONTENT_LENGTH_UNKNOWN);
          server.send(200, "text/html", ""); // Empty content inhibits Content-length header so we have to close the socket ourselves.
          server.sendContent(webpage);
          webpage = "";
        void SendHTML_Content() {
          webpage = "";
        void SendHTML_Stop() {
          server.sendContent("");
          server.client().stop(); // Stop is needed because no content length was sent
        void SelectInput(String heading1, String command, String arg_calling_name) {
          SendHTML_Header();
          webpage += F("<h3>"); webpage += heading1 + "</h3>";
          webpage += F("<FORM action='/"); webpage += command + "' method='post'>"; // Must match the calling argument e.g. '/chart' calls '/chart' after selection but with arguments!
          webpage += F("<input type='text' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>");
          webpage += F("<type='submit' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>");
          webpage += F("<a href='/'>[Back]</a>");
          SendHTML_Content();
          SendHTML_Stop();
        void ReportSDNotPresent() {
          SendHTML_Header();
          webpage += F("<h3>No SD Card present</h3>");
          SendHTML_Content();
          SendHTML_Stop();
        void ReportFileNotPresent(String target) {
          SendHTML_Header();
          webpage += F("<h3>File does not exist</h3>");
          webpage += F("<a href='/"); webpage += target + "'>[Back]</a><br><br>";
          SendHTML_Content();
          SendHTML_Stop();
        void ReportCouldNotCreateFile(String target) {
          SendHTML_Header();
          webpage += F("<h3>Could Not Create Uploaded File (write-protected?)</h3>");
          SendHTML_Content();
          SendHTML_Stop();
        String file_size(int bytes) {
          String fsize = "";
          if (bytes < 1024)                 fsize = String(bytes) + " B";
          else if (bytes < (1024 * 1024))      fsize = String(bytes / 1024.0, 3) + " KB";
          else if (bytes < (1024 * 1024 * 1024)) fsize = String(bytes / 1024.0 / 1024.0, 3) + " MB";
          else                              fsize = String(bytes / 1024.0 / 1024.0 / 1024.0, 3) + " GB";
          return fsize;
        and this is the page
        void append_page_header() {
          webpage  = F("<!DOCTYPE html><html>");
          webpage += F("<head>");
          webpage += F("<title>File Server</title>"); // NOTE: 1em = 16px
          webpage += F("<meta name='viewport' content='user-scalable=yes,initial-scale=1.0,width=device-width'>");
          webpage += F("<style>");
          webpage += F("body{max-width:65%;margin:0 auto;font-family:arial;font-size:105%;text-align:center;color:blue;background-color:#F7F2Fd;}");
          webpage += F("ul{list-style-type:none;margin:0.1em;padding:0;border-radius:0.375em;overflow:hidden;background-color:#dcade6;font-size:1em;}");
          webpage += F("li{float:left;border-radius:0.375em;border-right:0.06em solid #bbb;}last-child {border-right:none;font-size:85%}");
          webpage += F("li a{display: block;border-radius:0.375em;padding:0.44em 0.44em;text-decoration:none;font-size:85%}");
          webpage += F("li a:hover{background-color:#EAE3EA;border-radius:0.375em;font-size:85%}");
          webpage += F("section {font-size:0.88em;}");
          webpage += F("h1{color:white;border-radius:0.5em;font-size:1em;padding:0.2em 0.2em;background:#558ED5;}");
          webpage += F("h2{color:orange;font-size:1.0em;}");
          webpage += F("h3{font-size:0.8em;}");
          webpage += F("table{font-family:arial,sans-serif;font-size:0.9em;border-collapse:collapse;width:85%;}");
          webpage += F("th,td {border:0.06em solid #dddddd;text-align:left;padding:0.3em;border-bottom:0.06em solid #dddddd;}");
          webpage += F("tr:nth-child(odd) {background-color:#eeeeee;}");
          webpage += F(".rcorners_n {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:75%;}");
          webpage += F(".rcorners_m {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:50%;color:white;font-size:75%;}");
          webpage += F(".rcorners_w {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:70%;color:white;font-size:75%;}");
          webpage += F(".column{float:left;width:50%;height:45%;}");
          webpage += F(".row:after{content:'';display:table;clear:both;}");
          webpage += F("*{box-sizing:border-box;}");
          webpage += F("footer{background-color:#eedfff; text-align:center;padding:0.3em 0.3em;border-radius:0.375em;font-size:60%;}");
          webpage += F("button{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:130%;}");
          webpage += F(".buttons {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:80%;}");
          webpage += F(".buttonsm{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:9%; color:white;font-size:70%;}");
          webpage += F(".buttonm {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:70%;}");
          webpage += F(".buttonw {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:40%;color:white;font-size:70%;}");
          webpage += F("a{font-size:75%;}");
          webpage += F("p{font-size:75%;}");
          webpage += F("</style></head><body><h1>File Server "); webpage += String(ServerVersion) + "</h1>";
        void append_page_footer(){ // Saves repeating many lines of code for HTML page footers
          webpage += F("<ul>");
          webpage += F("<li><a href='/'>Home</a></li>"); // Lower Menu bar command entries
          webpage += F("<li><a href='/download'>Download</a></li>");
          webpage += F("<li><a href='/upload'>Upload</a></li>");
          webpage += F("</ul>");
          webpage += "<footer>&copy;"+String(char(byte(0x40>>1)))+String(char(byte(0x88>>1)))+String(char(byte(0x5c>>1)))+String(char(byte(0x98>>1)))+String(char(byte(0x5c>>1)));
          webpage += String(char((0x84>>1)))+String(char(byte(0xd2>>1)))+String(char(0xe4>>1))+String(char(0xc8>>1))+String(char(byte(0x40>>1)));
          webpage += String(char(byte(0x64/2)))+String(char(byte(0x60>>1)))+String(char(byte(0x62>>1)))+String(char(0x70>>1))+"</footer>";
          webpage += F("</body></html>");
