    Degrees C Symbol
    11 Posts 4 Posters 25.0k Views 2 Watching
    • m5stackM Online
      m5stack @richardmckenna
      @richardmckenna The character " ° " is not in the range of ASCII code. So it cannot be displayed, maybe you can try to use " 'C " symbol instead, it will look more same
        richardmckenna @m5stack
        @m5stack hmmm ok that's a shame.
        I don't suppose you can suggest any other way of displaying it? Would have thought it was a common thing to do given temperature applications are a popular thing for this kind of hardware.
        Is there any documentation on what characters are available? Or is it just the standard ASCII set but not the extended set?
        • m5stackM Online
          @richardmckenna You can refer to this Unicode example, but in fact it still does not support displaying " ° ", but will be able to display more characters. Please pay attention to the content of the notes when using.
          Github link: https://github.com/m5stack/M5Stack/tree/master/examples/Advanced/Display_Unicode
            @m5stack Thank you I will take a look.
            • world101W Offline
              world101
              I manually create the degree symbol by drawing a white circle and then a smaller black circle on top. But it takes some trial and error depending on your text size.
                richardmckenna @world101
                @world101 thanks. I think I will do this.
                  peter153
                    peter153
                      peter153
                      //Fake degrees C Symbol
                      String strTemp;
                      strTemp = String(temp1 + strtof(&adj1[0], NULL));
                      strTemp += " C";
                      M5.Lcd.drawCentreString(strTemp,320/2,50,1);
                      //M5.Lcd.print(String(temp1 + strtof(&adj1[0], NULL))+"℃"); //broken --;
                      int nTempLen=strTemp.length();
                      M5.Lcd.setTextSize(1);
                      M5.Lcd.setCursor(2, 50);
                      M5.Lcd.print("Sensor");
                      M5.Lcd.print(" 1");
                      if(nTempLen==6)
                      M5.Lcd.setCursor(195, 45);
                      else if(nTempLen==7)
                       M5.Lcd.setCursor(205, 45);
                      else if(nTempLen==8)
                       M5.Lcd.setCursor(216, 45);
                      else
                       M5.Lcd.setCursor(200, 45);
                      M5.Lcd.setTextSize(2);
                      M5.Lcd.print("o"); //lowcase o
                      • world101W Offline
                        world101
                        Just an update. I noticed that uiFlow now supports Unicode characters. I'm not sure in which release it was introduced, but I'm now able to add the degree symbol to a label using characters from this site.
                        Two drawbacks...
                        • Size is fixed at unicode 24 (similar in size to DejaVu 24).
                        • Unicode 24 is missing from the label set font block
