    All IDE refuse to work with M5Stack now
    SOFTWARE
    5
    11
    17.9k
    • K
      kylebuttress
      I have found the same with USB connected devices they are very difficult to connect with.
        I'm finding this aswel.
        @m5stack any idea what happened?
        • T
          Thrasher
          I'm not sure but there's probably major changes with 1.6 and later. Thats why UIFlow desktop not upgrading aswell
          • m5stackM
            which device are you use?
            • T
              Thrasher
              @m5stack M5Stack core gray with 1.6.1 UIFlow firmware
              • m5stackM
                m5stack @Thrasher
                @thrasher did you setup the device to USB mode?
                we has test it. it working normal with vscode. maybe you could try to erase flash then upload the firmware again.
                • lukasmaximusL
                  Make sure you have the stickC in USB mode, it's a little tricky, you need to hit the button on the right side really quickly on bootup. If you want to use in MU you need to change a config file, I mention it in this video https://youtu.be/15JrXn_9OWQ?t=80
                  • T
                    Thrasher
                    Yeah thanks @lukasmaximus and @m5stack
                    Ofcourse its on USB mode, I spent day trying different tricks with MU and THonny but I was using m5stack basic gray module, not stickC/Atom (I have them both so will try hopefully this weekend)
                    VS Code won't work still, it sends M5Stack into reboot and than can't access its inner memory, but it could be a driver issue, will keep trying
                    What's about offline uiflow ide?
                    • m5stackM
                      m5stack @Thrasher
                      @thrasher update your vscode and plugin and UIFlow desktop IDE to last version. then try again.
                      • T
                        Thrasher @m5stack
                        @m5stack
                        Hi, yes, with some updating and couple restarts VS Code now working with 1.6.1 UIFlow firmware
                        Thank you
