UIFlow 1.5.4
@m5stack Sorry today is all about me
I don't know what I did wrong when I first tested it. -
@plusulli so it working normal right now?
@m5stack said in UIFlow 1.5.4:
yes it works normal thank you for this function it is great
USB mode gone from Stick-C?? New "code" menu goes directly to Cloud mode. But in the cloud UI I cannot load blocklys from my computer. Is there a secret to enabling USB mode?
@cortado or maybe driver for MacOS needs update. Tried on my PC and could connect via the UART app :)
How do you use the AC socket as it an RS 485 device not a unit?
@ajb2k3 yeah. ACSocket is a RS485 slave device. you need use RS485 communication to control it.
@m5stack I'm trying to use the base26 rs485 adapter.
Ouu the new burner looks nice!
Yep new Beta burner is great ! but got a bug with COM port refresh
Check this out, erased or burned one Lite then another was connected with diff COM but when i try to burn / erase there is old come exist.
@mati thank you feedback. we will fix this bug as soon as possible
What's the latest stable (non beta) release of UIFlow, is that still 1.4.5? (When I download the version from https://m5stack.com/pages/download , I get 1.4.5)
@sjako you could select 1.4.5/1.5.4 two UIFlow version in the navigation right side.
@m5stack Thanks, I found it, it was a bit hidden =)
Maybe it should be a bit more clear 1.5.4 is a beta version? Maybe add a "b" after 1.5.4? Before I also tried the following option, but that's a completely different revision number
@cortado They changed the method to get into USB mode, which is a little tricky, press the left hand button on your stick-c to reset and then quickly press the button on the right side to enter usb mode, the usb symbol will appear if you are successful
@sjako in the check update page.the version number is desktop IDE software version.
no hat and blocks for the rgb neoflash hat!
no blocks for neo butterfly launcher
StickC's not connecting to my wifi but my Core is connecting to my wifi!
@ajb2k3 maybe you could check the ssid and password make sure they not problem. or erase the device flash then try again.
