    UIFlow 1.5.2
    Official Updates
    9
    28
    99.6k
    • T
      Thrasher
      7: Add: Modbus support.
      Yeeha prayers answered, will be testing tomorrow!
      • H
        Hugo
        Works only first publish command. Why?
        edit: sometimes first two. I have to change order for publish third configuration topic
          IR unit not supported
          • m5stackM
            m5stack @Hugo
            @hugo could you provide whole program screenshot?
            • E
              Efried
              It does no see the emoji library...
              • m5stackM
                m5stack @Efried
                @efried thank you feedback , we will fIx this bug as soon as possible
                • T
                  tialm
                  Is it possible to know more about the ncir unit correction? What was wrong before? Asking because I am using a costume micropython version and want to know if I have to change something in my code.
                  Thanks!
                  • J
                    jpilarski
                    Very thankful for you all getting ble added to m5stack micropython. However I did notice a bug; it looks like
                    blynk.init('fire', 'xxxxxxxxxxxxxxxxxxxxxx', blynk.BLE) needs to be added in prior to any of the other blynk related functions but it is often being added in after the other functions and this causes the board to become idle and while it doesn't throw any errors, it also doesn't successfully run the code as intended. I am sure this is a pretty easy fix. For now it looks like the workaround is to copy and paste the autogenerated python blynk related code into the correct order.
                    • m5stackM
                      m5stack @jpilarski
                      @jpilarski first add blynk init is necessary. if you use block program. you should put the blynk.init block to the setup. before use other blynk block.
                      • J
                        jpilarski
                        The problem I am having looks to be whenever I add certain blocks, for example the loop block, it changes the position of the blynk.init() code and puts it several lines lower in the python code and thus out of order. Even when the blynk.init() was previously working, as soon as I add certain blocks, it puts the blynk.init() several lines lower in the code and this is preventing blynk from working and requires the user the manually cut and paste the blynk.init() line to put it in the correct position. Maybe I'm wrong about how I am using the the blynk blocks. It would be great to see a few screen shots showing how other users are implementing the blocks. thanks
                        m5stackM R 2 Replies Last reply Reply Quote 0
                        • m5stackM
                          m5stack @jpilarski
                          @jpilarski could share you program ? I have test it. event i add a loop block. the blynk init seem still in the correct position. so if you could take a screenshot show me the program, it will very helpful for us to solve this problem.
                          • J
                            jpilarski
                            @m5stack
                            Here is a quick example
                            This code doesn't ever connect to blynk. Here is the code it generates:
                            from m5stack import *
                            from m5ui import *
                            from uiflow import *
                            from ble import blynk
                            setScreenColor(0x222222)
                            label0 = M5TextBox(52, 10, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            label1 = M5TextBox(46, 49, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            circle0 = M5Circle(141, 122, 15, 0xFFFFFF, 0xFFFFFF)
                            val = None
                            message = None
                            blynk.init('fire', 'xxx', blynk.BLE)
                            while True:
                              circle0.setSize(val)
                              wait_ms(2)
                            @blynk.handle_event('connected')
                            def blynk_write():
                              global val, message
                              rgb.setColorAll(0xff0000)
                              pass
                            @blynk.handle_event('write v2')
                            def blynk_write(*args):
                              global val, message
                              val, message = args[0], args[1]
                              label0.setText(str(val))
                              label1.setText(str(message))
                              pass
                            Here is the manually adjusted code that connects with blynk.
                            from m5ui import *
                            val = None
                            message = None
                            def blynk_write():
                              global val, message
                              pass
                              global val, message
                              pass
                            while True:
                              wait_ms(2)
                            In the example above when the message variable is shown using label1.setText(str(message)) it shows the following ['255']. What is the most effective way in micropython to remove the [] and ' ' and convert message variable to an integer. I am using
                            which outputs this
                              global val, message
                              message = str(message.replace("'", '').replace(']', '').replace('[', ''))
                              circle0.setSize(int(message))
                              pass
                            but should generate this
                              global val, message
                              message = str(message).replace("'", '').replace(']', '').replace('[', '')
                              pass
                            • R
                              robalstona @jpilarski
                              @jpilarski Some time ago I did custom blocks for blynk. They use rest api requests for communication, so they are not as advanced as those from uiflow. maybe these will work for you. I tested them on m5stickC and works.
                              https://github.com/stonatm/UiFlow-custom-blocks/blob/master/blynk/README.md
                              • J
                                jpilarski
                                @robalstona @m5stack Thanks for that suggestion. I'll try the blocks you developed out on StickC. The new ble blynk blocks work it"s just they require a little tinkering with the micropython code to get them connected. At least that is my experience of using them. I am still very happy to see them included in the latest beta version of uiflow. Also I look forward to seeing a screen_shot showing all the blocks operating together in a single setup because I might be setting them up in a way that introduces the minor issues I've come across.
                                • m5stackM
                                  m5stack @jpilarski
                                  @jpilarski ok, the problem is clear. thank you feedback, we will fix this bug ASAP.
                                  • J
                                    jpilarski
                                    @m5stack
                                    Very cool. Thanks and it's really great to see bluetooth in micropython and uiflow. At one time you mentioned the micropython firmwares would be open source and made available on github, I know you have a uiflow micropython repo https://github.com/m5stack/UIFlow-Code but it doesn't always get updated with new releases, it would be great to see the repo get updated and have branches for each major release. I think so much great development can happen if the code is made available.
                                    • m5stackM
                                      m5stack @jpilarski
                                      @jpilarski You can talk about which lib your users want to open source.
                                      • T
                                        Thrasher @m5stack
                                        @m5stack
                                        Can we have document with something like:
                                        UIFlow lib
                                        --API
                                        --Methods
                                        --Method example / construction
                                        The way Arduino document its built-in libraries or similar to this?
                                        Thank you
                                        • m5stackM
                                          m5stack @Thrasher
                                          @thrasher
                                          we had open source part UIFlow lib code. in this github :https://github.com/m5stack/UIFlow-Code
                                          Taking into account some lib data security issues, we will not open source all libs for the time being, so you can talk about which libs users want, we will consider if open source these lib.
                                          • T
                                            Thrasher @m5stack
                                            @m5stack
                                            I don't need source code.
                                            I'd like documentation on API usage
                                            E.g. LCD
                                            -Lcd.print(text, posx, posy, size) - prints a text string
                                            Etc.
                                            Im not looking for any source code
                                            Here's example from arduino:
                                            https://www.arduino.cc/en/reference/libraries
                                            And detailed info on functions:
                                            https://www.arduino.cc/en/Reference/SD
                                            No source code there but all functions detailed and explained how to use
                                            Because blockly, Im sorry, is just lame
