    UIFlow 1.5.1
    Official Updates
    6
    15
    25.5k
    • M5StickFreaklerM
      M5StickFreakler
      Sorry since Update 1.5.x it is not possible, that I connect my devices via Usb.
      Upload fails.
      I use Desktop M5Flow 1.0.9
      I got this UIFlow-Error:
      [Window Title]
      Error
      [Main Instruction]
      A JavaScript error occurred in the main process
      [Content]
      Uncaught Exception:
      Error: Port is not open
          at SerialPort.close (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:425:29)
          at SerialPort.<anonymous> (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\src\libs\serialport.js:217:34)
          at SerialPort._error (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:197:14)
          at binding.open.then.err (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:241:12)
      [OK]
      I can Reset the device and then reconnect it.
      Then I see a green "connected" in left bottom corner.
      After I try to upload some code, I get ever and ever again an error and device is disconnected.
      Sometimes I can "run" my code.
      But if I upoload the code to the device I get an Error:
      File "<string>", line 1
      SyntaxError: invalid syntax
      First line in code is:
      from m5stack import *
      It is really unusable since some few weeks.
      Before it was working well (but not perfect)
      • P
        plusulli
        Where is the Demo for M5stickC ?
          I'm getting issues with using the earth unit on fw 1.5.1
          uiflow is calling adc instead of earth
            @m5stack FW1.5.1 and UIFLow web 1.5.1
            When trying to use the earth sensor (2 prong moisture sensor) firmware respond with Unit ADC and no function getRawValue.
            • m5stackM
              m5stack @ajb2k3
              @ajb2k3 OK, Thank you feedback. we will fix this bug as soon as possible
              • m5stackM
                m5stack @plusulli
                @plusulli for the time being, M5StickC don't have 1.5.1 FW. pls patient wait.
                  ajb2k3 @m5stack
                  @m5stack AttributeError 'i2c' object has no attribute 'begin'
                  • m5stackM
                    m5stack @ajb2k3
                    @ajb2k3 after what operation it return this error?
                      ajb2k3 @m5stack
                      @m5stack Sorry should have said.
                      Trying to use the NCIR unit on port A
                      • m5stackM
                        m5stack @ajb2k3
                        @ajb2k3 ok......we will tracking this issues
                          @m5stack DCMotor and fan can not be controlled using PWM.
                          • G
                            Guors
                            @m5stack FYI! I receive the error "DAC object has no attribute 'waveform' " in UIFlow when using the "dac0 waveform with..." block. Is this due to the last firmware? Thanks!
                            • P
                              Pumpui @M5StickFreakler
                              • m5stackM
                                m5stack @Guors
                                @guors thank you feedback. we will fix this bug as soon as possible
