    M5StickC/ATOM on MacOS Catalina can't upload/ ESP32: Timed out waiting for packet header solution (Solved)
    Official Updates
    19
    44
    255.2k
    • R
      Redes.io @m5stack
      @m5stack Sorry ... Extremely new with a M5StickC. Having issues trying to connect M5StickC to UIFlow.
      I think this is the issue I am having , since I have MacOS (Catalina), downloaded Solution2 file, not familiar with terminal commands. I can't make this file to run... help
      File - Get Info
      -Sharing & Permissions
      • Everyone / Read and write
      Open terminal
      -cd ~/Downloads
      -chmod + x ch552Updater_FW20200102_BTV231
      -chmod: x: No such file or directory
      -chmod: ch552Updater_FW20200102_BTV231: No such file or directory
      What am I doing wrong?
      • world101W
        world101 @Redes.io
        @redes-io said in M5StickC and ATOM on MacOS platform can't upload programs solustion:
        File - Get Info
        Open terminal
        -cd ~/Downloads
        The instructions are incorrect. There should not be a space in between +x.
        cd ~/Downloads
        chmod +x ch552Updater_FW20200114_A2_BTV231.dms
        Then follow the instructions as written above.
        • R
          Redes.io @world101
          @world101 Thank you for the info.
          I did how you instructed and it just doesn't do any thing. The terminal just doesn't do anything the file doesn't open anything.
          Thanks.
          • world101W
            world101 @Redes.io
            @redes-io
            All I did was show you how to change the executable permissions of the file. That was your issue. You still need to follow the rest of the instructions they provided....
            “Then connect the M5StickC device to the computer, double-click to open the tool, follow the operation prompts, press the Enter key to run, and wait for the burning to complete.”
            R C 2 Replies Last reply Reply Quote 0
            • R
              Redes.io @world101
              @world101 Very much appreciated, thank you for the reply!
              • C
                cortado @world101
                @world101 Remember to remove the .dms file extension, which is wrongly added by Safari/MacOS. Then you should be able to execute the file by right-clicking and choosing "open in Terminal", then follow instructions.
                  sergey.maysak
                  Just want to confirm this solution as working for M5Stick-C and M5Atom... I'm on latest macOS 10.15.3 (19D76).
                  • m5stackM
                    m5stack @sergey.maysak
                    @sergey-maysak Theoretically this solution applicable , and we already has test , you could try it.
                    • C
                      cepics
                      @world101 said in M5StickC and ATOM on MacOS platform can't upload programs solustion:
                      ==================== M5 Serial Converter Firmware Updater ====================
                      FW Version: FW20200114_A2
                      This is only for update M5StickC or M5Atom Series USB Controller's Firmware
                      , using it for any other purpose may cause damage to your devices.
                      When you are using this software, make sure you have a reliable connection
                      to your device. Any disruption during the process will cause the device
                      not functioning.
                                          NO WARRANTIES
                      To the extent permitted by applicable law, neither wsdot,
                      nor any person, either expressly or implicitly, warrants any aspect of
                      this software or program, including any output or results of this software
                      or program. Unless agreed to in writing. This software and program is
                      being provided "as is", without any warranty of any type or nature,
                      either express or implied, including, but not limited to, the implied
                      warranties of merchantability and fitness for a particular purpose,
                      and any warranty that this software or program is free from defects.
                      Press enter to continue . . .
                      Detecting M5Stack products.
                      Find M5Stack products.
                      Kernel driver deteched.
                      Apply magic success.
                      Fail to cast magic stage 2, please contact vendor.
                      Waiting for device in DFU mode.....................logout
                      Saving session...
                      ...copying shared history...
                      ...saving history...truncating history files...
                      ...completed.
                      Deleting expired sessions...153 completed.
                      [Process completed]
                      not working to me M5Atom LITE on osx 10.12.5
                      • C
                        cepics
                        where is the G0 on M5Atom LITE??
                        • m5stackM
                          m5stack @cepics
                          @cepics Why do you want to upgrade ... 10.12 can support the ATOM. This upgrade tool is for those systems that don't recognize the port such as MacOS Catalina
                          • C
                            cepics
                            I have problems to upload code on M5StickC and M5Atom LITE.....
                            no serial port available in tools/port menu..
                            I have also burn with easyloader (on a win machine) to reset the modules
                            osx 10.12.5
                            arduino IDE 1.8.9
                            • m5stackM
                              m5stack @cepics
                              @cepics you could try setup the baud to 115200. then try again. or contact our store. we will help you solve it. as soon as possible
                              • H
                                HerrLehmann @m5stack
                                @m5stack
                                I'm on macos 10.15.3 and I'm asking myself too, where is G0 on the M5Atom Matrix? Although I was able to apply the described firmware, I'm not able to connect via UIFlow IDE nor Arduino IDE (1.8.9).
                                By the way: almost no image gets displayed on Safari from the documentation — neither iPad nor mac.
                                • m5stackM
                                  m5stack @HerrLehmann
                                  @herrlehmann M5Atom Matrix have not provided G0 Pin to outside. so the solustion 1 is for m5stickC. and could you use windows os test it again? maybe is the driver software problem .
                                  • C
                                    cepics @m5stack
                                    @m5stack said in M5StickC and ATOM on MacOS Catalina can't upload programs solustion:
                                    no way!!! Atom serial port doesn't appear in the serial port list..... more than one cable tested....
                                    • H
                                      @m5stack
                                      No, the is (un)fortunately no Windows machine. I'm a little confused about the fact, that the above mentioned firmware is running without any problem. So there needs to be a connection between mac to m5atom in some way — or how is it writing to the device?
                                      • R
                                        RschDev
                                        My new m5stick-C are showing up on the MacOS (10.15.3) as M5 Serial Converter, and in the Arduino IDE (latest edition). I have applied the updater as suggested in this thread, and still get this response when trying to upload from the IDE to the device: "fork/exec /Applications/Arduino 2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags: bad CPU type in executable
                                        Error compiling for board M5Stick-C."
                                        • m5stackM
                                          m5stack @RschDev
                                          @rschdev clearly. this is a compiling error . you should check the error information , and check you program.
                                          • m5stackM
                                            @herrlehmann did you installed the FTDI driver? you could try delete both below files. then connect your device try again.
                                            /Library/Extensions/FTDIUSBSerialDriver.kext
                                            /Library/Extensions/FTDIKext.kext
                                            H 2 Replies Last reply Reply Quote 0
