    Description M5Stack 6060-PUSH
    13 Posts 4 Posters 24.5k Views 1 Watching
    • m5stackM Online
      m5stack @sheepDog
      @sheepdog
      you can refer 6060 product document.
      link : https://docs.m5stack.com/#/en/1515/6060-push
        sheepDog
        @m5stack
        I know the link at your answer. At the linked webpage is no information about pinout or details of the commands! Can you help me?
        ajb2k3A m5stackM 2 Replies Last reply Reply Quote 0
          ajb2k3 @sheepDog
          @sheepdog said in Description M5Stack 6060-PUSH:
          @m5stack
          The 6060 Push is not well documented.
          Have you seen this page?
          https://docs.m5stack.com/#/en/uiflow/RS485
          • m5stackM Online
            m5stack @sheepDog
            @sheepdog actually you just need look at the Product Photo . you can found the commands.
              sheepDog @ajb2k3
              @ajb2k3 Thank you for the new link, I didn't know this page
              @m5stack I saw the commands at the product photo, but this didn't answer my questions:
              1. Where is which Pin (G = GND , V = Voltage, RS485-A, RS485-B)
              2. Which voltage is correct? 24V?
              3. What is the answer of the commands, for example -ID<number>I\r\n - Read busy -
                I share the opinion that the component is currently not well documented. Sorry.
                ajb2k3 @sheepDog
                @sheepdog some more information
                Pins are show here.
                alt text
                alt text
                Voltage is 12 to 24 vdc.
                https://docs.m5stack.com/#/en/accessory/485t
                https://docs.m5stack.com/#/en/base/plc_base
                https://docs.m5stack.com/#/en/app/ac_socket
                  ajb2k3 @ajb2k3
                  @m5stack In the descriptions of RS485 I see mention of a 100 (120 ohm in the picture above) ohm termination resistor. Is this in each of the devices or is it needed?
                  • O Offline
                    option
                    Use one 120ohm resistor in each end of the bus.
                    If unclear try google for "rs485 termination"
                      ajb2k3 @option
                      @option said in Description M5Stack 6060-PUSH:
                      That's what caused me to ask!
                      @option I just need to check with m5stack before recording in my book.
                        sheepDog
                        @ajb2k3 and @option Thank you for your help.
                        • m5stackM Online
                          m5stack @ajb2k3
                          @ajb2k3 Usually not required, it is recommended to add it for long distance communication
                            ajb2k3 @m5stack
                            @m5stack Thanks.
