    M5Stack + NRF24 = LCD slow down
    4 Posts 2 Posters 6.0k Views 2 Watching
    • jpbbricoleJ Offline
      jpbbricole
      Hi!
      I'm using a M5Stack Gray, with a NRF24L01 radio transmitter.
      #include <M5Stack.h>
      #include <RF24.h>
      //------------------------------------- Radio RF24
      #define rf24CePin 16
      #define rf24CsnPin 17
      RF24 RF24(rf24CePin, rf24CsnPin);
      As soon as I invoke a RF24 function like RF24.available() or RF24.printDetails(), the LCD display of the M5Stack slows down dramatically.
      At the start, the SPI BUS of the M5Stak is at 40mHz (In_eSPI_Setup.h #define SPI_FREQUENCY 40000000 // Maximum to use SPIFFS), it seems to me that it falls below 1mHz.
      Why?
      Thanks for your help
      cordially
      jpbbricole
        jpbbricole
        Hi
        I found the reason for the slowdown of the LCD display, it's in RF24-master library, file RF24.cpp.
                    #elif F_CPU < 320000000
                    _SPI.setClockDivider(SPI_CLOCK_DIV32);
        As the speed of the M5Stack is 24000000, that divided the frequency of the SPI by 32.
        I added
                     #elif F_CPU == 240000000                     // For M5Stack Grey
                    _SPI.setClockDivider(SPI_CLOCK_DIV2);                // For M5Stack Grey
        and the problem is solved.
        Thanks for reading me
        cordially
        jpbbricole
        • world101W Offline
          world101
          Glad you found the issue. I’m interested in seeing your full code once you have it done. I’m also interested in using the NRF24L01 in a project idea that I have been thinking of.
            jpbbricole
            Hi world101
            To make this modification, I determined the speed of the M5Stack by making a program with:
            Serial.println (F_CPU)
            which gave 24000000
            Then, I modified the file ..\libraries\RF24-master\RF24.cpp by adding these lines (who have // For M5Stack Gray as a remark)
            #if !defined(SOFTSPI)
                _SPI.setBitOrder(MSBFIRST);
                _SPI.setDataMode(SPI_MODE0);
                        #if !defined(F_CPU) || F_CPU < 20000000
                            #elif F_CPU < 40000000
                    _SPI.setClockDivider(SPI_CLOCK_DIV4);
                            #elif F_CPU < 80000000
                    _SPI.setClockDivider(SPI_CLOCK_DIV8);
                            #elif F_CPU < 160000000
                    _SPI.setClockDivider(SPI_CLOCK_DIV16);
                    _SPI.setClockDivider(SPI_CLOCK_DIV2);                // For M5Stack Grey**
                            #elif F_CPU < 640000000
                    _SPI.setClockDivider(SPI_CLOCK_DIV64);
                            #elif F_CPU < 1280000000
                    _SPI.setClockDivider(SPI_CLOCK_DIV128);
                            #else
                                #error "Unsupported CPU frequency. Please set correct SPI divider."
                            #endif
                        #endif
            Regarding the program where I use the RF24, it is very large, I can, if you want, give you an example of use, with several pipes.
            cordially
            jpbbricole
