    How could I make text to speech using the speaker?
    SOFTWARE
    6
    15.2k
    • A
      AndreaF
      I have M5stickC with speaker hat. I'm wondering if it's possible to perform text to speech routines in order to allow the speaker to speak a string.
      • ChrisWRC
        ChrisWR
        This works on the M5stack, for the stickC I cannot test tho..
        #include <M5Stack.h>
        #include <M5StackUpdater.h>
        #include <Arduino.h>
        #include <ESP8266SAM.h>  //https://github.com/earlephilhower/ESP8266SAM
        #include <AudioOutputI2S.h>  //https://github.com/earlephilhower/ESP8266Audio
        AudioOutputI2S *out = NULL;
        void setup()
          Wire.begin();
          if(digitalRead(BUTTON_A_PIN) == 0){
            Serial.println("Will load menu binary");
            updateFromFS(SD);
            ESP.restart();
          out = new AudioOutputI2S(0, 1, 32);
          out->begin();
        void loop()
          ESP8266SAM *sam = new ESP8266SAM;
          sam->Say(out, "Can you hear me now?");
          delay(500);
          sam->Say(out, "I can't hear you!");
          delete sam;
        • ChrisWRC
          ChrisWR
          Try this for the M5stickC could work, ...
          #include <M5StickC.h>
          void setup()
            out->begin();
          void loop()
            delay(500);
            delete sam;
          X 1 Reply Last reply Reply Quote 1
          • X
            xis @ChrisWR
            @chriswr It works on the M5stickC :)
            Can you explain the line " out = new AudioOutputI2S(0, 1, 32);" ?
            What do the numbers 0, 1, 32 mean?
            Thank you.
            • X
              xis
              I see some examples, like here :
              https://www.xtronical.com/i2sinternetradio/
              There is a line:
              // audio.connecttospeech("Wenn die Hunde schlafen, kann der Wolf gut Schafe stehlen.", "de");
              It seems to be another way, but you can choose the language.
              Could this work on the M5stickC with the SPK HAT?
              What do I put on DIN connection, Bit clock, and Left Right Clock?
                makadodo
                @chriswr said in How could I make text to speech using the speaker?:
                delay(500);
                delete sam;
                @ChrisWR will this work with ATOM Echo Smart Speaker Development Kit? https://m5stack.com/collections/m5-atom
                • M mtrobregado referenced this topic on
