    M5StickC HAT PIN control in UIFlow
    UIFlow
    5
    6
    10.9k
    • A
      AndreaF
      M5StickC has these 8 PIN
      GND, 5V OUT, G26, G36, G0, BAT (what is?), 3V3, 5V IN
      I cannot find a match in Uiflow. Uiflow pin block allows me to select pin0, pin1, pin2 ,pin3 , pin4.
      alt text
      Other doubt
      With just Uiflow firmware flashed and no other task running checking the pin with a multimeter. I have noticed that G26, G36, G0 haven't same voltage (G36 seems having a lower voltage). Why?
        ajb2k3 @AndreaF
        @andreaf individual pin control has not been yet provided for the hat connector
        • A
          AndreaF @ajb2k3
          @ajb2k3 Bummer. I hope this feature will be introduced soon. What about the different voltage on G26, G36, G0. Is that normal? If yes why one of the pin has much lower voltage?
          • lukasmaximusL
            I would hazard a guess, that one gpio is receiveing comands from the host, while the other is waiting for the user to send a command, therefore one pin will have a higher voltage when sending data, and the other will have a lower voltage or 0 while not receiving any data
            • K
              kotobuki
              I want to utilize the HAT pin in UIFlow to add a digital sensor. Are there any plans to support the HAT pin in UIFlow? Though I can code in the Arduino environment, I want to go with UIFlow if possible. Because UIFlow is easy to deploy and let non-experts tinker.
              Thanks.
              • world101W
                world101
                Unless I’m not understanding it correctly, according to the docs, you would select a pinX from the drop down list and type the pin number (ex: 26) into the Init pin block. Then you can get or set the pin via the other blocks. As far as pin0 through pin5, those seems to be a designator for the pin you are controlling.
                BAT = battery
