    Is there an easy way to connect M5Stack or M5Stick-C to old Lego Mindstorms Motors and Sensors (Robotic Invention)
    Modules
    30.7k
    • liemphL
      liemph @ajb2k3
      @ajb2k3 said in Is there an easy way to connect M5Stack or M5Stick-C to old Lego Mindstorms Motors and Sensors (Robotic Invention):
      This is the new NXT module for the M5Stack
      https://m5stack.com/collections/all/products/basex?ref=pfpqkvphmgr
      alt text
      It comes With NXT sockets which means you can use these adapters for RIS motors.
      link text
      alt text
      Thanks. This is a good solution.
      • liemphL
        liemph @Skink
        @skink said in Is there an easy way to connect M5Stack or M5Stick-C to old Lego Mindstorms Motors and Sensors (Robotic Invention):
        There I was not fast enough @ajb2k3.
        @ liemph,
        and here how you finish the cables : http://www.philohome.com/nxtcables/nxtcable.htm
        Ready to buy there were also times from the company: https://www.generationrobots.com/de/157-lego-mindstorms
        Cause I got a couple more ready to go here. But I'll keep them, of course. Since I also have RTX, NXT and EV3 here without end.
        Ok, those URLs are helpful. Thanks.
        • SkinkS
          Skink
          @liemph,
          here are some more interesting pages about the RCX.
          Maybe very interesting for you if you still have so many RCX parts.
          1. https://www.philohome.com/sdk25/sdk25.htm
          2. http://www.mralligator.com/rcx/
          3. http://lego.brandls.info/legbau.htm#code red
          greetings skink
          P.S. I'm waiting for two of the X-Base units, they're already on their way to my place
          liemphL 1 Reply Last reply Reply Quote 1
          • liemphL
            liemph @Skink
            @liemph,
            greetings skink
            Thank you. For long I have followed the first two links. The third is new to me. Please let me know your impression on the Base X. If I have an NXT Lego then I will certainly by the base.
            • SkinkS
              Skink
              @liemph
              No need to thank me, of course I will get in touch with you as soon as I have received them !
              And tell you what my impression of the X-Base is.
              • SkinkS
                Skink @liemph
                @liemph
                I had ordered the BaseX on 13 December 2019.
                Today finally on 21.01.2020 they arrived at my place.
                They are working very well, I will test them during the next days and make a little video!
                Greeting Skink
                • liemphL
                  liemph @Skink
                  @liemph
                  Greeting Skink
                  Happy Testing !!!
                  • SkinkS
                    Skink
                    I will test it at the weekend but for you @liemph I will test it with the adapters and the old Lego motors !
                    i Get touch as soon as I have tested it, it will only take a little while until Saturday before I can start !!
                    • SkinkS
                      Skink
                      @liemph ,
                      As you can see, you can connect all RCX engines and also the power engines to the BaseX and of course the old engines of the NXT as well as the EV3. For the power motors there are also adapters to connect them to the X-Base.
                      The X-Base can control both the direction of rotation and the speed of the motors.
                      For sensors you would have to use the M5Stack connectors, which are available!
                      I hope the test helped you !
                      Here the link to the video : "https://www.youtube.com/watch?v=xm5Hdaia7po"
                      greetings skink
                      • SkinkS
                        Skink
                        @liemph ,
                        With this adapter and the adapter from power motors to the old ones you can also make NXT or EV3 motors from the old motors which you can drive exactly on angle ! (http://www.mindsensors.com/ev3-and-nxt/19-glidewheel-pf-and-rcx-motor-controller-for-nxt-or-ev3-)
                        greetings skink
                        Video (https://www.youtube.com/watch?v=W1jNzYjn_bc&feature=youtu.be)
                        • SkinkS
                          Skink
                          You will need the following cables :
                          1. this one from NXT/EV3 to PF Power motor connector
                            (https://www.generationrobots.com/de/401189-cable-nxt-to-pf.html)
                          2. this one from PF Power Motor Connection to the old motors
                            (https://www.robot-advance.com/EN/art-extension-wire-8-20-cm-lego-power-functions-8886-en-777.htm)
                          Greeting skink
                          • liemphL
                            liemph @Skink
                            @liemph ,
                            greetings skink
                            Thanks, a very nice video that explains everything I wanted to know. The encoder signal is also used by the Base is impressive. This feedback is important for a serious project.
                            • liemphL
                              liemph @Skink
                              Greeting skink
                              Ok, this is another interesting way not to throw away old Lego motors. I am challenged to make those connectors. Awesome. Thanks.
                              • SkinkS
                                Skink
                                The encoder signal is displayed very accurately and also evaluated very precisely. Of course also with the NXT motors and EV3 motors. I will see that I make a video the days once again where you can see how precisely he drives the set values.
                                @liemph
                                I will then connect a NXT motor and run it on different values of the encoder! The GlideWheel PF and RCX motor controller for NXT or EV3 cannot be mounted directly on the old motors, because it is designed for the power motors (on these it is mounted with two pins), but you can mount it somewhere in the system on the shaft of the motor. So you can make an encoder motor out of any Lego motor.
