    M5StickC usb driver and Catalina
    30 Posts 12 Posters 132.1k Views 2 Watching
      sheepDog @sheepDog
      Is there any other way to change M5StickC to upload-mode? Ist isn‘t nice to change the connector every time I like to upload a new program. I used a joystick-modul and my upload-modul.
        flippycurb
        I can confirm that the workaround "Connect G0 pin to GND" works for me on Catalina 10.15.2. I am now able to write to the m5StickC wheras before it was stuck connecting eventually throwing the error "A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header". I am able to reproduce this on two m5StickCs. It's worth noting this is without any 3rd party drivers and after only following the steps given here - https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_arduino_MacOS
        Has there been any progress on resolving the issue?
          sheepDog @flippycurb
          In the meantime I tested three M5StickC and can not program anyone without "Connect G0 pin to GND". I changed from Arduino to esp-idf and got the same issue.
          After some analysis, I separated the problem: I think the esptool.py didn't work correct with the cp210x drivers. The critical part is:
            def _connect_attempt(self, mode='default_reset', esp32r0_delay=False):
              """ A single connection attempt, with esp32r0 workaround options """
              # esp32r0_delay is a workaround for bugs with the most common auto reset
              # circuit and Windows, if the EN pin on the dev board does not have
              # enough capacitance.
              # Newer dev boards shouldn't have this problem (higher value capacitor
              # on the EN pin), and ESP32 revision 1 can't use this workaround as it
              # relies on a silicon bug.
              # Details: https://github.com/espressif/esptool/issues/136
              last_error = None
              # If we're doing no_sync, we're likely communicating as a pass through
              # with an intermediate device to the ESP32
              if mode == "no_reset_no_sync":
                  return last_error
              # issue reset-to-bootloader:
              # RTS = either CH_PD/EN or nRESET (both active low = chip in reset
              # DTR = GPIO0 (active low = boot to flasher)
              # DTR & RTS are active low signals,
              # ie True = pin @ 0V, False = pin @ VCC.
              if mode != 'no_reset':
                  self._setDTR(False)  # IO0=HIGH
                  self._setRTS(True)   # EN=LOW, chip in reset
                  time.sleep(0.1)
                  if esp32r0_delay:
                      # Some chips are more likely to trigger the esp32r0
                      # watchdog reset silicon bug if they're held with EN=LOW
                      # for a longer period
                      time.sleep(1.2)
                  self._setDTR(True)   # IO0=LOW
                  self._setRTS(False)  # EN=HIGH, chip out of reset
                  if esp32r0_delay:
                      # Sleep longer after reset.
                      # This workaround only works on revision 0 ESP32 chips,
                      # it exploits a silicon bug spurious watchdog reset.
                      time.sleep(0.4)  # allow watchdog reset to occur
                  time.sleep(0.05)
                  self._setDTR(False)  # IO0=HIGH, done
              for _ in range(5):
                  try:
                      self.flush_input()
                      self._port.flushOutput()
                      self.sync()
                      return None
                  except FatalError as e:
                      if esp32r0_delay:
                          print('_', end='')
                      else:
                          print('.', end='')
                      sys.stdout.flush()
                      time.sleep(0.05)
                      last_error = e
              return last_error
          def connect(self, mode='default_reset'):
              """ Try connecting repeatedly until successful, or giving up """
              print('Connecting...', end='')
              sys.stdout.flush()
              last_error = None
              try:
                  for _ in range(7):
                      last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
                      if last_error is None:
                          return
                      last_error = self._connect_attempt(mode=mode, esp32r0_delay=True)
                          return
              finally:
                  print('')  # end 'Connecting...' line
              raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
          The esptool.py used reset with DTR and RTS and I suspect this part did not work correct, because any print of '.' or '_' showed a (fatal) error.
          My short test for all existing ports showed the error:
          $IDF_PATH/components/esptool_py/esptool/esptool.py chip_id
          • m5stackM Offline
            m5stack @sheepDog
            @sheepdog this problem from MAC OS FTDI driver , you can try to use WIN10 OS (like using a virtual machine) to upload program. also M5StickC Upload program don't need CP2104 Driver.
              sheepDog @m5stack
              @m5stack Thank you for your quick response. I am sure that Mac OS Catalina need a driver. A few days ago I installed Mac OS 10.15.2 form scratch and M5StickC needs the cp210x-driver (M5Stack needs the FTDI driver!).
              You can test it. If you connect a M5StickC you see at the directory /dev a file with this name "cu.usbserial-<number>". With connected M5Stack you see "cu.SLAB_USBtoUART" (<- This is the FTDI driver).
              My workaround is "Connect G0 pin to GND". That is not nice. Your solution to start a VM is even more complex because all need all my files there.
              Yes, I can program M5StickC, but I am looking for an easy way to program M5StickC with short turn around times and easy handling. Normally I used Atom editor with PlatformIO.
                tcruse
                @m5stack could you please advise on the best process for getting M5StickC to work and flash via esptool on Mac OS Catalina ?
                Also, advise on which driver is needed for M5StickC. Is it the FTDI driver or is it the CP210X driver ?
                • m5stackM Offline
                  m5stack @tcruse
                  @tcruse first , on some Mac PC, M5StickC cannot upload program properly.
                  the solution: When programming, short the G0 to GND using the DuPont line.
                  and , all most PC don't need driver with M5StickC. But some old PC System need install FTDI driver.
                  FTDI driver is for M5StickC, CP2104 driver is for M5Stack Core ( like Fire BASIC M5GO)
                    sheepDog @m5stack
                    @m5stack Yes, I swapped the drivers. You can check it at Apple menu, systemreport and USB.
                    1. If I connected a M5Stack I saw:
                    2. If I connected a M5StickC I saw:
                    You can check the loaded drivers and their versions in terminal with "sudo kextstat".
                    I noticed that sometimes M5Stack didn't not work without "short the G0 to GND". I think that is a timing-problem at Catalina and esptool.py. It is not a problem of M5Stack- or M5StickC-Software.
                      sheepDog
                      I formulated an Issue at Github: Link to Issue
                      Supplement on January 18, 2020: You need an Espressif account to see the issue.
                      • m5stackM Offline
                        m5stack @sheepDog
                        D S 2 Replies Last reply Reply Quote 0
                          diogovaraujo @m5stack
                          @m5stack Cant click that link.
                            sheepDog @m5stack
                            @m5stack
                            I got this error if I click your link: "Access denied. You do not have permission to access this page."
                            Thank you for updating your software.
                            • world101W Offline
                              world101
                              The link worked for me once a few hours ago, but now it’s not.
                              • N Offline
                                nsfilho @o.copleston
                                @o-copleston This solution is running perfectly! Thank you!
                                • m5stackM Offline
                                  m5stack @diogovaraujo
                                  It may make your firmware lose and make it unusable, so if you are willing to take this risk, you can chat with me in private and I will give you a link to download the tool @sheepDog @world101
                                    sheepDog @m5stack
                                    @m5stack Hello, are there any news about a solution for Catalina and M5StickC?
                                    • N Offline
                                      nsfilho @sheepDog
                                      @m5stack if you can, please give us the link for a new driver to solve that problem....
                                      • m5stackM Offline
                                        m5stack @nsfilho
                                        @nsfilho @sheepDog Please read the information carefully before using the tool
                                        link:
                                        http://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-platform-can-t-upload-programs-solustion
                                        • N Offline
                                          nsfilho @m5stack
                                          @m5stack Thank you! The solution 2 (as describe in link) is fully functional.
