    M5StickV link/Info dump.
    M5Stick V
    5
    14
    30.5k
    • T
      Thrasher
      Hey @sboger , do u have any progress with camera?
      I'm dragged into reading Maix's manuals and such but can't combine em into something, lol
        staberas
        hey can anyone confirm me what the value of getBatteryDischargeCurrent() is ? is it mA or battery % ?
        • X
          Xeon @staberas
          @staberas
          getBatteryDischargeCurrent() will show you the mA currently being drawn when the device is not being charged.
          The war of 1 and 0 draws ever closer.
          everyday i work to become a cyborg.
            staberas @Xeon
            @xeon
            Thanks, so if the value i get is 100mA then i have ~2hours run time based on the 200mAh battery correct? thou i have to keep the time passed since the last check to estimate battery %
            • X
              Xeon @staberas
              @staberas
              Theoretically yes.
              it should be near 2 hours.
              under heavy workloads it peaks to +-115mA
                staberas
                Adding my demo project as a sandbox for other users : https://github.com/staberas/Joker-Masks-M5StickV , it covers faces with joker mask
                  staberas
                  Can anyone point me on how you use the expansion slot?
                    ajb2k3 @staberas
                    @staberas said in M5StickV link/Info dump.:
                    what expansion slot?
                      staberas @ajb2k3
                      4pin expansion PH2.0-4
                        ajb2k3 @staberas
                        @staberas The grove port under the USB port?
                        Does it not work as a normal Grove Port A?
                          staberas @ajb2k3
                          yes, cant seem to find info on it
                          EDIT: i started testing the pins and i cant detect a voltage output
