    Goplus dc motor driver
    General
    5
    20
    38.4k
    • R
      rob.biernat
      Ok no probs. For now I have stuff going with a jumper wire hack but I can buy some proper jst cables tommorow.
      Is the person who wrote the go plus firmware and sample code on this forum? I can understand most of the code but since the code is not documented and not included in the m5 stack arduino library I need some help understanding the messages that get sent out on the i2c bus and what they do.
        ajb2k3 @rob.biernat
        @rob-biernat Looks like he is but he is not active.
        @zhouyang can you help?
        • R
          rob.biernat
          Ok so I have the dc motor controller working but when will the sample code be cleaned up and documented. At the moment it's a bit rough with lots of magic numbers scattered through the code. Ideally a proper api
          • R
            rob.biernat
            Any updates from the bloke who wrote the code?
            • R
              rob.biernat
              Anything from the programmer?
                ajb2k3 @rob.biernat
                @rob-biernat said in Goplus dc motor driver:
                Nope, still waiting.
                • lukasmaximusL
                  Is this the code in question?
                  #include <Arduino.h>
                  #include <M5Stack.h>
                  #define IrPin 13
                  #define PLUS_ADDR 0x62
                  int32_t number = 0;
                  uint8_t press = 0;
                      M5.begin(true, false, false);
                      M5.Lcd.setTextFont(6);
                      M5.Lcd.clear(BLACK);
                      M5.Lcd.setTextColor(ORANGE, BLACK);
                      Wire.begin();
                      ledcSetup(1, 38000, 10);
                      ledcAttachPin(IrPin, 1);
                  void plus_encode() {
                      Wire.requestFrom(PLUS_ADDR, 2);
                      while(Wire.available()) {
                          int8_t encode = Wire.read();
                          uint8_t press_n = Wire.read();
                          number += encode;
                          if(press_n == 0xff) {
                              press = 0;
                          else {
                              press = 1;
                      char data[20];
                      plus_encode();
                      ledcWrite(1, ledcRead(1) ? 0 : 512);
                      sprintf(data, "%d  %d        ", number, press);
                      M5.Lcd.setCursor(100, 100);
                      M5.Lcd.print(data);
                      vTaskDelay(200);
                  I have a feeling the engineer who wrote the code may no longer work at M5Stack but i'll make an enquiry.
                  • L
                    liushasha
                    @rob-biernat
                    PH2.0
                    https://item.taobao.com/item.htm?spm=a1z10.3-c-s.w4002-21223910208.112.64e66a4bJ99Q2L&id=522578768957
                    • R
                      rob.biernat
                      Ok given the bloke who wrote the code has left can someone please at least document the i2c messages?
                      • V
                        vany5921
                        https://github.com/m5stack/GoPlus/blob/master/src/src.ino this is sourece code
