    live motion tracking with multiple m5stickc in unity [QUESTION]
    PROJECTS
    6
    20
    38.2k
    • T
      Thrasher
      Yeah, with UIflow GetAccX blocks are not a problem, but sending data via socket connection? Could be solved easily with wifi <>uart esp32 mode but Im not sure its possible with uiflow
        shintobi @shintobi
        I started to use cloudmqtt and uiflow to send sensor data to my pc terminal via mqtt.
        I read that there is a mqtt lib for unity. So will try to research that. :)
          ajb2k3 @shintobi
          @shintobi that is a good idea but for a more local version, you could used an M5Stack as a hub that connects to the pc over uart and have the sticks send the data to the stack.
          UIFlow has peer to peer connections between units.
            shintobi @ajb2k3
            @ajb2k3 my goal is to make the communication wireless.
            do you mean i can get data from multiple devices in UIFlow at the same time?
            • W
              wikistik
              Have you considered using Bluetooth? I have connected a single Bluetooth tracking device (not from M5) to Unity without too much trouble. I believe Bluetooth supports up 7 clients connected at once.
                shintobi @wikistik
                @wikistik actually an interesting idea. do you also have experience connecting several m5s via bluetooth?
                • W
                  wikistik @shintobi
                  @shintobi no I don't
                    Okay, just got sent this link.
                    https://randomnerdtutorials.com/esp32-esp8266-raspberry-pi-lamp-server/
                    S C 2 Replies Last reply Reply Quote 0
                      shintobi @ajb2k3
                      @ajb2k3 damn. i just randomly got the thought to check the forum and see you posted 2 mins ago. crazy...
                      Thanks i will check it out
                        ajb2k3 @shintobi
                        @shintobi only got the email an 10mins befor posting on the forum
                        • lukasmaximusL
                          I remember a Japanese user posting a video on twitter about using the M5Stack as a controller in unity. I found his slides its all in Japanese I'm afraid and not possible to copy past the text to translate but here's the link https://speakerdeck.com/naninunenoy/m5stack-with-unity in the slides he mentions a bluetooth library called grayblue, might be worth a shot checking that out. I also found these other two blog posts covering the subject again in Japanese but this time at least you should be able to copy and paste the text to translate https://qiita.com/Zeni-Y/items/1d0e545259fbcd9381c8 and http://prince9.hatenablog.com/entry/2018/09/26/055809
                          C S 2 Replies Last reply Reply Quote 0
                          • C
                            cmisztur
                            @shintobi , just sent you a voucher to our Unity MQTT asset.
                            http://unity3dassets.com/demos/wak-mqtt-demo2/index.html
                            • C
                              cmisztur @ajb2k3
                              @ajb2k3 for this use case I would recommend streaming IMU data to InfluxDB. Seems more appropriate for limb tracking.
                              • C
                                cmisztur @lukasmaximus
                                @lukasmaximus , below is some code I used on PYCOM hardware and WebBluetooth. I ran into issues when getting characteristic notifications faster than 1/2 sec. Not sure if it was an IDF GATT issue or WebBluetooth or PYCOM implementation. But it did kinda work.
                                https://pastebin.com/We2S8JwR
                                https://pastebin.com/HDrktkQZ
                                https://pastebin.com/s23hUMiD
                                https://pastebin.com/WtWr9C2J
                                https://pastebin.com/7d9CEyuR
                                • lukasmaximusL
                                  @cmisztur thanks for sharing
                                    shintobi @cmisztur
                                    @cmisztur the unity mqtt asset looks nice. but where can i put port / user / pwd? :D
                                    i am using cloudmqtt as my broker.
                                      shintobi @lukasmaximus
                                      @lukasmaximus will check it out. thanks!
                                      • C
                                        cmisztur @shintobi
                                        @shintobi check out some of the scenes like ping-pong. It’s in a script on a GO.
