    M5burner on windows7 cannot flash
    28 Posts 5 Posters 103.7k Views 1 Watching
    • Ariane98A Offline
      Ariane98
      Code runs on the stick, excepted whan I try to use IMU.
      Both firmware and UIFlow are UIFlowv1.3.2
      ajb2k3A Ariane98A 2 Replies Last reply Reply Quote 0
        ajb2k3 @Ariane98
        @ariane98 Which stick?
        The old black or the Orange Stick C?
        • Ariane98A Offline
          Ariane98 @Ariane98
          Orange
          • Ariane98A Offline
            Ariane98
            btw, in arduino, how do you access the built in red led?
            Docs showed pin 10 but it's no working...
              ajb2k3 @Ariane98
              @ariane98 said in M5burner on windows7 cannot flash:
              Try GPIO10
              Ariane98A 1 Reply Last reply Reply Quote 0
              • Ariane98A Offline
                Ariane98 @ajb2k3
                Strangely, it does light the led when I use digitalWrite(10, HIGH) but then nothing happens with digitalWrite(10, LOW)
                If I use digitalWrite(10, LOW) first, it sets the led ON...
                  Ok I'm running 1.4 and getting a syntex error.
                  Try upgrading to 1.4.0 beta and try again.
                  • Ariane98A Offline
                    Ariane98 @ajb2k3
                    Thanks for your help
                    I intended to use m5stick with kids but maybe it's too early...
                    Both UIFlow and Arduino environments seem still unpredictable
                      ajb2k3 @Ariane98
                      @ariane98 Its strange because all I use is UIFlow and I am writing an english book on it (samples available to download in the projects forum)
                      For the current M5StickC competition i'm using the IMU in my project however, I'm using the online version and programming over wifi.
                      • Ariane98A Offline
                        Ariane98 @ajb2k3
                        I am using UIFlow online too, but no luck with IMU...
                        • Ariane98A Offline
                          Ariane98 @ajb2k3
                          is it possible too use the stick as a vry simple webserver?
                            Don't know about the web server but here is my imu test file
                            https://github.com/Ajb2k3/UIFlowHandbook/blob/master/main (8).m5f
                            • Ariane98A Offline
                              Ariane98 @ajb2k3
                              I get the same I2C bus error
                              If I upload it to the stick I get a grey screen with no data displayed
                              • Ariane98A Offline
                                Ariane98 @Ariane98
                                updated to 1.4.0 beta and that's OK now
                                Thank you
                                I've looked at your book...quite nice
                                  ajb2k3 @Ariane98
                                  Thank you
                                  Its still WIP and I am open to comments a criticism.
                                  • lukasmaximusL Offline
                                    @Ariane98 you can check out my guide for simple webserver, it's written for the M5Stack in micropython, but you shouldn't have any problems running it on the stick c https://www.hackster.io/lukasmaximus89/m5stack-micropython-simple-web-server-20a4c4
                                    I'm curious to know what age students were you thinking of using the stick c to teach with?
                                    • Ariane98A Offline
                                      Ariane98 @lukasmaximus
                                      @lukasmaximus
                                      kids from 8 to 14
                                      I've had workshops with "bare" ESP32 and an online coding tool
                                      Interesting but too complex to be fun for kids
                                      • Ariane98A Offline
                                        Ariane98 @Ariane98
                                        @ariane98
                                        Regarding you guide, I uploaded it and the screen shows 4 "Labels" saying Text. It does not mention wifi connexion, or failed connexion
                                        • Ariane98A Offline
                                          Ariane98 @Ariane98
                                          @ariane98
                                          It works now, after some minor changes
                                          Thanx again
