Windows M5Burner Proxy support
Hey !
Please consider to add proxy support inside burner. Now we 1.0.0 version with Settings tab, maybe in future rls we can find there
Use network proxy Yes
IP / port / type of authRegards
Mati -
Hi @Mati thanks for your suggestion. Do I understand correctly that you wish to have a feature where the user can define their own proxy server to host their own firmwares?
@lukasmaximus said in Windows M5Burner Proxy support:
Hi Lukas,
well here is full story:
At work on my corporate PC whole network traffic req connection via proxy. So with internet browser its easy just go to option and setup a proxy and go.In M5 Burner we can't do this. First run of Burner req a downloading a proper SW packages for example Beta UIFlow etc. This step will fail without proxy setup inside Burner.
If there is still some questions let me know.
Regards
Hi @Mati Sorry to hear about your situation, I have forwarded this issue on to the development team. Meanwhile if you are familiar with esptool you can use it to flash the latest firmware which can be found here: https://github.com/EeeeBin/UIFlow-Firmware/tree/beta
@lukasmaximus well this is a issue only in proxy restricted networks. So its non critical or blocker.
Its could be add to considering in next MBurner sprint.Thx for reply Lukas
@mati said in Windows M5Burner Proxy support:
proxy
Its not easy to add a Proxy support, in this situation you can try to download easy loader on the documentation page.
A proxy restriction network? Would installing a VPN service not be better?
