šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    M5StickC Nixie tube Clock
    PROJECTS
    8
    28
    117.4k
    • SkinkS
      Skink @ajb2k3
      the battery is full, even if I leave the M5Stick-C connected to the laptop, the Nixi clock disappears after a second and the screen stays black, but you can still see the backlight.
      What I haven't understood about the manual so far is the following part:
      Update Nixie Tube images
      Execute the lcd-image-converter.exe include in this repository.
      " Png or Jpg is read from File->Open Menu. The image will be displayed when loaded.
      Select: Option->Conversions Menu. The top Preset: selects "Color R5G6B5".
      Select: Image tap and select ā€œ8 bitā€ for Block size :. Press "OK".
      The example "vfd_35x67_8.c" is output by "Convert ..." in File-Convert Menu. Know in advance the destination path. Tick: Import All Images You can also output all the images with ā€œConvert ... allā€.
      Edit .c converted file. You will get an error as it is, so fix it with your editor.
      " Change: "Static const uint8_t image_data_vfd_35x67 [4690] = {" at the top of the file deleting "image_data_" as result of "static const uint8_t vfd_35x67_8 [4690] = {".
      At the bottom of delete de entire line: "const tImage vfd_35x67 = {image_data_vfd_35x67, 35, 67, 8};
      Save the example "vfd_35x67_8".c***
      When I load the file M5StickC-Nixie-tube_clock.ino into Arduino, both files vfd_1834.c and vfd_3567.c are loaded automatically.
      Where or what should I change !
      Don't understand this !
      Greetings Reiner
        ajb2k3 @Skink
        @skink I'm not sure as i just down loaded and compiled/flash strait to the stick c.
        one thing to try is to download m5burner, wipe and install uiflow. the try re compiling and uploading in arduino.
        is it only the nixi tube demo doing this?
        • SkinkS
          Skink @ajb2k3
          @ajb2k3 Yes it is only with the Nixi Tube demo, all other examples from the Arduino application run without problems.
          Just started UI-Flow Desktop application and install UIFlow-v1.3.4 beta with M5Burner now.
          And then I will install the Nixi Clock again by Arduino software.
          Unfortunately we don't see any success with UIFlow-v1.3.5 beta.
          Yes, the problem only occurs during the Nixi tube demo.
          If something is missing at Arduino or like already ajb2k3 writes maybe it is due to the libs 1.0.2 how do I install the 1.22 ???
          Maybe it works then.
          Too bad you always see it for a second and the Nixi clock looks really awesome.
          Greetings Reiner
            ajb2k3 @Skink
            @skink All you are doing is using UIFlow to clear the program storage space on the M5Stack. I'm confused because my stick C is working as it should and not showing a blank screen after a few seconds.
            • SkinkS
              Skink @ajb2k3
              Well, I'm afraid I don't know any more advice either. Try to attach a video, if possible.
              This is what it looks like in any case, I only deleted the memory with M5 Stack Burner and then played the Nixi Clock with Arduino, the same result unfortunately!
              Greetings Reiner
              P.S. Unfortunately I don't have the possibility to upload a video here. Too bad
              • SkinkS
                Skink
                @ to all
                I noticed something else interesting, but I don't know if it has anything to do with it, I plug the M5Stick-C into the USB port and the M5Stick-C is displayed with "USB Serial Port (COM11)" under the COM&LPT ports.
                If I connect one of my M5Stack modules to the USB port, the M5 stack are displayed with "Silicon Labs CP210x USB to UART Bridge (COM6)" under the COM&LPT ports.
                Should the M5Stick-C not display the same Silicon Labs CP210x ....?
                Do I have to assume otherwise that it is defective!
                Otherwise I would order one more !!
                Greetings Skink
                P.S. The display of the port doesn't change if I switch the M5Stick-c to USB mode or to Wifi-Cloud mode via UIFlow!
                • SkinkS
                  Skink
                  m5stick-c
                  • SkinkS
                    Skink
                      No, the StickC appears differently to other devices
                      • P
                        purilovec
                        I have the following question: The nixie clock works fine, but when I switch the m5sitcc off - the RTC does not continue to count. After switching on it shows the time shown exactly before switching off. Is that a software or hardware problem?
                        • SkinkS
                          Skink
                          @ all,
                          I have now performed the same steps again (installation Arduino and installation M5StickC_Nixi_tube-Clock) on my desktop PC. And see there also with me now the Nixi Clock runs on the M5StickC.
                          What it is between laptop and desktop PC is that the clock on the laptop after the installation on the display briefly appears and disappears again and on the desktop PC appears and remains, I can not explain myself.
                          Maybe it's again due to driver problems or the Windows version that I have chosen the USB 3.0 port for both!
                          Laptop Windows 1903 Version, Desktop PC Windows 1803 or the UIFlow-Desktop Version and Visual Studio Code are installed on the laptop and the drivers don't get along.
                          Thanks for your helpful support Greetings skink
                          • P
                            PMX @purilovec
                            @purilovec said in M5StickC Nixie tube Clock:
                            Same for my Stick: After powering on, the clock starts with the time the skech was compiled. Looks like the Time/Date is'nt read from the RTC.
                            • world101W
                              world101
                              I implemented the Nixie tube clock in uiFlow IDE for the M5StickC-Plus device.
                              https://github.com/bstein2379/M5StickC-Plus-Nixie-clock
                              Credit goes to @macsbug for the original idea. I just made it easier for new programmers and kids by using the uiFlow IDE.
